[Fdo-trac] [fdo-trac] #974: Creating a spatial context with a dot (.) in the name makes it un-destroyable
trac_fdo at osgeo.org
Wed Oct 14 04:09:24 PDT 2026
destroyable
Reporter: jng | Owner: danstoica
Type: defect | Status: closed
Priority: major | Milestone: 4.2.0
Component: SQLServer Spatial | Version: 4.1.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8402" 8402]:
{{{#!CommitTicketReference repository="" revision="8402"
Ticket #974, #550: SQL Server Spatial dotted spatial context and missing
primary key error
Two SQL Server Spatial defects, both reported against this provider.
Ticket #974 ("Creating a spatial context with a dot (.) in the name makes
it
un-destroyable") reports that a spatial context whose name contains a dot
cannot
be destroyed. In a datastore without a meta-schema a spatial context is
recorded
as a geometry column of the special f_scinfo table, named after the
context, so
its spatial index name inherits the dots: "Spatial.Context.With.Dots"
becomes
f_scinfo_spatial.context.with.dots_si_srid=26741. That name is qualified
with an
owner - the qualifier of the containing table's name ("dbo.f_scinfo"), or,
when
that name is itself unqualified, the "dbo" that
FdoSmPhSqsMgr::GetRealDbObjectName() prepends to unqualified names. A
spatial
index is scoped to its table in SQL Server, so the DDL must use the
unqualified
name, and the code produced it with name.Right(L"."), which returns
everything
after the first dot. That is only correct for a name that actually carries
a
qualifier: applied to the name read back from sys.indexes, which does not,
it
discarded the leading part of the name as well. The name the DROP
statement was
built from therefore no longer matched the name the index had been created
with,
and the destroy failed with "Cannot drop the index
'dbo.f_scinfo.with.dots_si_srid=26741', because it does not exist or you
do not
have permission", leaving the spatial context in place.
The owner qualifier is now removed only when the name actually starts with
it, so
one rule holds for both a name that carries a qualifier (new index) and a
name
that does not (read back from the database, which is how a later session
sees the
index). The qualifier is taken from the containing table's name, falling
back to
"dbo" for the unqualified f_scinfo name, and the remainder of the name -
dots
included - is kept, which is what makes the same index name reachable from
the
CREATE and the DROP statement.
Ticket #550 ("SQL Spatial - poor error message when trying to insert into
a table
without a primary key") reports that inserting into a table with no
primary key
fails with "Creating/Updating a standalone instance for class 'X' is not
allowed", which gives no hint of the cause. A table without a primary key
reverse-engineers to a class without an identity property, which is the
condition
CheckClass() rejects, and the message named the class but never the table,
although the missing primary key on that table is the whole problem. When
the
class is backed by a table the exception now names the table and says its
primary
key is missing; the previous message is kept for a class that has no
database
object, where there is no table to name.
Provider:
Providers/GenericRdbms/Src/SQLServerSpatial/SchemaMgr/Ph/SpatialIndex.cpp:
SqsUnqualifiedIndexName() removes the owner qualifier only when the name
carries it, taking the qualifier from the containing table's name and
defaulting to "dbo" for an unqualified table name.
FdoSmPhSqsSpatialIndex::GetDDLName() and Add() use it in place of the
name.Right(L".") they used before; the name given to SQL Server for an
index
without dots is unchanged.
* Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsSchemaUtil.cpp:
CheckClass()
throws the new message when the class has no identity property and is
backed by
a database object, and the previous one otherwise.
* Providers/GenericRdbms/Nls/fdordbmsmsg.mc: adds FDORDBMS_551
(MessageId=2776),
"Creating/Updating a standalone instance for class '%1$ls' is not
allowed
because table '%2$ls' has no primary key." Existing ids are untouched;
the
header the message compiler generates from this file
(Inc/Nls/fdordbmsmsg.h) is
written by the build and is not under version control.
Tests:
* SqlServerFdoSpatialContextTest::testDottedSpatialContext creates a
spatial
context named "Spatial.Context.With.Dots", checks that it is listed,
destroys
it and checks that it is gone. The destroy step is what failed before
this
change, with the DROP INDEX error quoted above.
* SqlServerFdoInsertTest::testDefect550 builds the ticket's table
(char(36) id,
geometry and varchar columns, no primary key), sets it as the class of
an
FdoIInsert and asserts that the exception reports the missing primary
key.
Verified with the SQL Server Spatial suites in the Debug configuration:
FdoSpatialContextTest OK (6), FdoInsertTest OK (14), the two together OK
(20),
FdoUpdateTest and FdoDeleteTest OK (15), and FdoApplySchemaTest OK (5) -
the last
being the suite that exercises spatial index names without dots and the
regression gate for the qualifier change. Both new tests were also run
against
the source they replace and failed there: testDottedSpatialContext with
the DROP
INDEX error, and testDefect550 with the message that did not identify the
primary
key. A sweep of sys.indexes across all 44 fdo_* test databases confirms
that no
spatial index name kept an owner qualifier, which is the property the DROP
statement depends on.
Fixes #974
Fixes #550
Ticket URL: <https://trac.osgeo.org/fdo/ticket/974#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
