[Fdo-trac] [fdo-trac] #734: Problem reading negative Int64 values
trac_fdo at osgeo.org
Wed Oct 14 02:23:02 PDT 2026
Reporter: simonpel | Owner: haris
Type: defect | Status: closed
Priority: major | Milestone: 3.5.0
Component: KingOracle Provider | Version: 3.5.0
Severity: 3 | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"8400" 8400]:
{{{#!CommitTicketReference repository="" revision="8400"
Ticket #734: Negative values and unrecognized OCI conversion failures
Ticket #734 ("Problem reading negative Int64 values") reports that reading
a
negative Int64 returns "GetInt64 : Exception unrecognized" and crashes the
client. Two things were behind that, and this change set covers both.
Reading the value: the provider narrows the Oracle NUMBER it fetched back
to a
C integer with OCINumberToInt, and that conversion has to be told the
value is
signed. The 3.5-era code performed it as OCI_NUMBER_UNSIGNED inside
GetLong(),
so Oracle rejected every negative value (ORA-01426). GetLong() was
replaced by
GetInt64() (OCI_NUMBER_SIGNED, sizeof(FdoInt64)) in r7061, which also
switched
GetInteger() to OCI_NUMBER_SIGNED, so the reported case already passes on
this
branch; no provider change was needed for it, and what was missing was
coverage.
Reporting the failure: when an accessor cannot narrow the value it read,
OCI
reports it through a raw c_Oci_Exception, and that is where the ticket's
"Exception unrecognized" comes from - a client cannot interpret that type.
The
numeric accessors of both readers now raise the FdoCommandException a
client
can read, carrying the OCI message ("OCI-22053: overflow error"), which
also
removes c_KgOraReader::GetInt32's catch that printed the error and
returned 0:
an unreadable value was indistinguishable from a genuine zero.
Provider:
* c_OCI_API: OciErrorToFdoException() turns the c_Oci_Exception an
accessor
reported into an FdoCommandException carrying the OCI text, taking over
the
exception it is given.
* c_KgOraReader: GetInt16, GetInt32, GetInt64, GetSingle and GetDouble
route
their statement accessor's OCI error through it.
* c_KgOraSQLDataReader: the same five accessors.
Tests:
* DataTypeTests::NegativeNumbers reads negative values back through
FdoISQLDataReader for every width OCINumberToInt narrows - Int16, Int32
and
Int64 (NUMBER(4,0), NUMBER(9,0), NUMBER(19,0)), plus Single, Double and
a
scaled NUMBER - once with a small negative and once with the smallest
value
the column can hold, asserting the FDO types reported for the columns
too.
* DataTypeTests::NegativeFeatureValues covers the feature commands: a
negative
identity and Int32 are inserted with FdoIInsert and the identity is read
back
from the command's own reader, then read by an equality filter built
from an
FdoInt64Value, by a text range filter and through an ordered select, and
an
update and a delete are executed against a filter matching the negative
key.
It also asserts that reading the Int64 minimum through GetInt32 raises
instead of returning 0.
* DataTypeTests::NumberOutOfRange asserts that a NUMBER(19,0) holding 19
nines
- one row negative, one positive - fails as an FdoException carrying the
OCI
text rather than as an unrecognized exception, and that the Int64
minimum,
which does fit Int64, is still readable through the same statement.
Verified with the full KgOraUnitTest suite against Oracle XE 11g: OK (42)
in
the Debug (ASan) and Release configurations, the Debug run with no
LeakSanitizer report. Both halves were also run against the behaviour they
replace: with OCI_NUMBER_UNSIGNED restored in c_Oci_Statement the two
value
tests fail, and with OciErrorToFdoException rethrowing the raw
c_Oci_Exception
instead of converting it, the two reporting tests fail - each with an
uncaught exception of unknown type,
the client-visible form of the error ticket #734 reports - while the
pre-existing cases still pass.
Fixes #734
Ticket URL: <https://trac.osgeo.org/fdo/ticket/734#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
