[Fdo-trac] [fdo-trac] #1023: SQLServerSpatial: Spatial queries against geography columns are winding-order sensitive
trac_fdo at osgeo.org
Sun Oct 25 17:45:49 PDT 2026
order sensitive
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: major | Milestone: 4.2.0
Component: SQLServer Spatial | Version:
Severity: 3 | Keywords:
External ID: |
I was testing the newly minted SQLServerSpatial provider on Linux by
loading the SHP Sheboygan dataset into it and setting up the
[FeatureSource > LayerDefinitions > MapDefinition] in MapGuide.
Rendering works, but selection was weird, as though the box geometry I
used to select features was actually being inverted to everything but the
region inside the box.
DeepSeek analysis revealed that geography columns in SQL Server are
winding-order sensitive and that although FDO had winding order
capabilities to check for this, we weren't actually leveraging this
anywhere.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1023>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
