[Fdo-trac] [fdo-trac] #1023: SQLServerSpatial: Spatial queries against geography columns are winding-order sensitive
FDO trac_fdo at osgeo.org
Sun Oct 25 18:17:58 PDT 2026
order sensitive
 Reporter:  jng                |        Owner:  jng
     Type:  defect             |       Status:  closed
 Priority:  major              |    Milestone:  4.2.0
Component:  SQLServer Spatial  |      Version:
 Severity:  3                  |   Resolution:  fixed
 Keywords:                     |  External ID:
Changes (by jng):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"8425" 8425]:
 {{{#!CommitTicketReference repository="" revision="8425"
 SQLServerSpatial: reorient geography literals to the class's polygon
 vertex order rule
 SQL Server's geography type does not treat a polygon's rings as a
 container with an
 inside: it reads the ring direction as which side of the ring is the
 interior, so a loop
 wound the other way round describes everything except the area it
 encloses. The provider
 passed the caller's literal through unchanged, so a box selection against
 a geographic
 feature class selected the whole table, and an insert or update stored the
 complement of
 the polygon it was given. In MapGuide this surfaces as DB_LOG_BUFFER_FULL
 on the
 persisted selection, because selecting the whole table makes the selection
 blob larger
 than the session repository's log buffer.
 Every stage below the caller was already correct - BuildPolygon writes
 rings in arrival
 order with ring 0 as the exterior ring - so the winding the client sent is
 the winding
 SQL Server saw. The capability was already advertised, and already plumbed
 as far as the
 class definition: FdoSmPhSqsDbObject::GetPolygonVertexOrderStrictness()
 reports a geography
 column as strict, and FdoSmLpClassBase::Capabilities carries that up to
 it. What was
 missing is the consumer - FdoSpatialUtility::FixPolygonVertexOrder()
 applies a rule, but
 nothing on the path that binds a filter literal or a stored value called
 it.
 FdoRdbmsSchemaUtil::FixGeometryVertexOrder() now reads the rule and the
 strictness the
 class advertises for the property and reorients a literal through
 FdoSpatialUtility::FixPolygonVertexOrder() when - and only when - the rule
 is declared
 strict. Strictness is the guard rather than the rule itself: among the
 GenericRdbms
 providers only a SQL Server geography column declares it, so planar
 geometry columns and
 the MySQL, PostGIS and ODBC literals pass through unchanged, and a
 deliberately large
 geography polygon is still expressible through a provider that does not
 declare
 strictness. It is applied on both sides:
   - FdoRdbmsSqlServerFilterProcessor and FdoRdbmsSqlServerSqlBuilder
 reorient the filter
     literal;
   - the four bind sites that write geometry - FdoRdbmsSimpleInsertCommand,
     FdoRdbmsSimpleUpdateCommand, and the insert and update PVC handlers -
 reorient stored
     values.
 The reoriented values are owned by FdoRdbmsGeometryValueOwner for as long
 as the command
 or filter processor that binds them lives, so a command that reuses its
 bound parameters
 keeps the fixed literal instead of reverting to the original on rebind.
 Tests:
 * SqlServerFdoSelectTest::TestSpatialGeogWinding selects the same box
 wound both ways
   against a geography column and requires the same two features. It fails
 without the
   change (cwNames->GetCount() == ccwNames->GetCount()) and passes with it.
 The suite had
   no coverage for this because TestSpatialGeog associates its geometry
 property named Geog
   with the projected spatial context projSC, so that fixture never created
 a geography
   column at all.
 Verified on ubuntu22 amd64 against the dbs/docker-compose.yml mssql_cs
 fixture
 (Latin1_General_CS_AS), Debug (ASan/LSan) and Release, through
 run_fdo_tests.sh
 --with-sqlserver-init:
 * FdoSelectTest: Run: 26, Failure total: 2 before the change and 1 after,
 the failure the
   change clears being TestSpatialGeogWinding.
 * UnitTestSQLServerSpatial, whole suite, Debug: OK (290) in 22m 39s on a
 freshly recreated
   mssql_cs. 3 direct leak records remain, all of them allocating in test
 code
   (TestSpatialGeog's CreateLinearRing,
 TestExplicitPropertyListGeometryTypes'
   FdoIdentifier::Create, and a dropped FdoSchemaException from the
 negative DropDatastore
   path); none has a frame in this change.
 * UnitTestMySql OK (249), UnitTestPostGis OK (140) and UnitTest (SHP) OK
 (138) are
   unchanged, and are the suites that compile the same RDBMS bind code.
 Fixes #1023
Ticket URL: <https://trac.osgeo.org/fdo/ticket/1023#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
