[fdo-users] Acsde sdo update
Brad Nesom
bnesom at acogok.org
Wed Apr 4 09:03:53 EDT 2007
We are a subscription map on 2007 right now. I will upgrade when 08 arrives.
I am considering implementing mgos. That is what I am working on here. We
have esri arcgis server advanced enterprise (which means sde, ims, gis
server). We are trying to get more familiar with the technology and decide
what we will implement.
I have a beta site profile but haven't requested the map 08 just because of
time restraints. My 07 connects to my 92sde (unsupported) with the
limitations mentioned earlier.
Brad
-----Original Message-----
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Wednesday, April 04, 2007 7:48 AM
To: Brad Nesom
Subject: RE: [fdo-users] Arcsde sdo update
Brad,
I meant: what app are you using? Map 2008 Beta, MapGuide OpenSource or
MapGuide Enterprise, etc.
RF
Sent: Tuesday, April 03, 2007 10:07 PM
To: Robert Fortin
I am using 9.2 and oracle 10r2.05
From: "Robert Fortin" <robert.fortin at autodesk.com> Yes. That's one part of
it. We also didn't want to impose 9.1 client component on the user.
So we are creating a front end dll loaded that will load the correct
provider depending on the presence of the arcSDE components. It will try to
load 9.2 components first and if it doesn't succeed, it will try the 9.1
components.
What are you using? we can probably give you something to try out.
RF
_____
Sent: Tuesday, April 03, 2007 2:56 PM
To: Robert Fortin
Yes I don't have any problem with the connection. The only problem is that
all number fields show up but no text fields do.
So you are just reworking the dlls to link to the new libs?
Brad
_____
Sent: Tuesday, April 03, 2007 1:01 PM
To: Brad Nesom; fdo-users at lists.osgeo.org
Brad,
Did you try 9.1 client with 9.2 server?
We are working on linking with the 9.2 client libs. Once we are done, it
should run with 9.1 or 9.2 client component.
RF
_____
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Tuesday, April 03, 2007 12:39 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Arcsde sdo update
Is anyone planning on updated the arcsde fdo? I still can't access my text
columns on my 9.2 sde data. As far as I can tell everything else is hunky.
Thanks
Brad
_________________________________________________________________
Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings
https://www2.nextag.com/goto.jsp?product=100000035
<https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&se>
arch=mortgage_text_links_88_h2bbb&disc=y&vers=925&s=4056&p=5117
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070404/307f42fa/attachment-0001.html
More information about the fdo-users
