[fdo-users] FDO 3.2 usage clarification
Dan Stoica
dan.stoica at autodesk.com
Fri Apr 20 14:36:54 EDT 2007
FDO 3.2 needs MySql 5.0.22. Don't use higher releases!
Here is the link:
http://downloads.mysql.com/archives.php?p=mysql-5.0
Dan.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
kgrootendorst at baird.com
Sent: Friday, April 20, 2007 2:12 PM
To: Jason Birch
Cc: MapGuide Users Mail List; fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] FDO 3.2 usage clarification
Jason,
Thanks for the reply. I 'found' MySQL dlls that were dated Mar/Apr 2006
(not sure what version) and that allowed me to connect to MySQL, but I
wasn't able to do anything beyond testing the connection in Studio. So
I assumed that I was not using the correct dlls, and thought I had read
somewhere that only FDO 3.2 is compatible with MGOS 1.1. And the only
instruction I found for installing FDO 3.2 was the build documentation,
which to be honest, is a little intimidating to me.
Before I installed the MySQL dll mentioned above, I did not see a list
of Feature Providers in Studio - so I assumed it was up to me to install
them.
Kevin
"Jason Birch" <Jason.Birch at nanaimo.ca>
04/20/2007 01:54 PM
To
<fdo-users at lists.osgeo.org>, "MapGuide Users Mail List"
<mapguide-users at lists.osgeo.org>
cc
<kgrootendorst at baird.com>
Subject
Hi Kevin,
I haven't tried to connect to MySQL from MapGuide yet, not sure what
MySQL versions are supported.
Have you installed the MySQL dlls on your MapGuide server machine? I
don't think that we are distributing these with MapGuide at this point
(could be wrong).
Jason
_____
Subject: [fdo-users] FDO 3.2 usage clarification
Hello,
I'm a new user to MGOS 1.1 (Win2000). Can someone confirm that if I
want to be able to connect to MySQL 5, I must build FDO open source
manually? There is no pre-compiled install file or anything like that
available at this time? I have the build instructions for Windows, but
before I tackle this I wanted to make sure there wasn't an 'easier' way.
Thanks,
Kevin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070420/8eff2d47/attachment-0001.html
More information about the fdo-users
