[fdo-users] FDO 3.2 usage clarification
kgrootendorst at baird.com kgrootendorst at baird.com
Fri Apr 20 15:42:19 EDT 2007
Dan - thanks. I have switched to 5.0.22, but my problem still persist.
Maybe that was just a tip for when/if I have to build FDO 3.2?
Kevin
______________________________
"Dan Stoica" <dan.stoica at autodesk.com>
04/20/2007 02:37 PM
To
<kgrootendorst at baird.com>, "Jason Birch" <Jason.Birch at nanaimo.ca>
cc
"MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>,
<fdo-users at lists.osgeo.org>
Subject
RE: [fdo-users] FDO 3.2 usage clarification
FDO 3.2 needs MySql 5.0.22. Don?t use higher releases!
Here is the link:
http://downloads.mysql.com/archives.php?p=mysql-5.0
Dan.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
Sent: Friday, April 20, 2007 2:12 PM
To: Jason Birch
Cc: MapGuide Users Mail List; fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] FDO 3.2 usage clarification
Jason,
Thanks for the reply.  I 'found' MySQL dlls that were dated Mar/Apr 2006
(not sure what version) and that allowed me to connect to MySQL, but I
wasn't able to do anything beyond testing the connection in Studio.  So I
assumed that I was not using the correct dlls, and thought I had read
somewhere that only FDO 3.2 is compatible with MGOS 1.1.  And the only
instruction I found for installing FDO 3.2 was the build documentation,
which to be honest, is a little intimidating to me.
Before I installed the MySQL dll mentioned above, I did not see a list of
Feature Providers in Studio - so I assumed it was up to me to install
them.
Kevin
04/20/2007 01:54 PM
To
<fdo-users at lists.osgeo.org>, "MapGuide Users Mail List"
cc
Subject
Hi Kevin,
I haven't tried to connect to MySQL from MapGuide yet, not sure what MySQL
versions are supported.
Have you installed the MySQL dlls on your MapGuide server machine?  I
don't think that we are distributing these with MapGuide at this point
(could be wrong).
Jason
Subject: [fdo-users] FDO 3.2 usage clarification
Hello,
I'm a new user to MGOS 1.1 (Win2000).   Can someone confirm that if I want
to be able to connect to MySQL 5, I must build FDO open source manually?
There is no pre-compiled install file or anything like that available at
this time?  I have the build instructions for Windows, but before I tackle
this I wanted to make sure there wasn't an 'easier' way.
Thanks,
Kevin
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070420/8cfc5a4b/attachment.html
More information about the fdo-users mailing list
