[fdo-users] King Fdo2Fdo copy problem
Haris Kurtagic
haris at sl-king.com
Tue Aug 7 17:42:47 EDT 2007
Did you get any error message ?
F2FCmd and Fdo2Fdo GUI interface are using same library Fdo2FdoApi.dll
for executing Copy Task XML file.
Input parameter to API is XML file itself, so it should work in a same
way ( or at least it is intended so :) ).
Haris
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Binter Jan
Sent: Tuesday, August 07, 2007 4:50 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] King Fdo2Fdo copy problem
We want to use command line version - F2FCmd.exe. But we are not able to
copy data, using CopyTask parameter. I am attaching XML definition which
works in GUI version, but does not work in command line. Please can you
help us?
Thanks Jan
More information about the fdo-users
