[fdo-users] King Fdo2Fdo copy problem
Binter Jan
Jan.Binter at xanadu.cz
Thu Aug 9 03:27:57 EDT 2007
Yes, the error message is attached.
> Did you get any error message ?
> F2FCmd and Fdo2Fdo GUI interface are using same library Fdo2FdoApi.dll
> for executing Copy Task XML file.
> Input parameter to API is XML file itself, so it should work in a same
> way ( or at least it is intended so :) ).
> Haris
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Binter Jan
> Sent: Tuesday, August 07, 2007 4:50 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] King Fdo2Fdo copy problem
> We want to use command line version - F2FCmd.exe. But we are not able
to
> copy data, using CopyTask parameter. I am attaching XML definition
which
> works in GUI version, but does not work in command line. Please can
you
> help us?
> Thanks Jan
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Type: image/gif
Desc: taskcopy_error.gif
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20070809/dd58d5b9/taskcopy_error.gif
More information about the fdo-users
