[fdo-users] Unable to test PostGis provider
Mateusz Loskot
mateusz at loskot.net
Tue Aug 14 20:20:29 EDT 2007
Bruno Scott wrote:
> Hi all
> i'm trying to test the new pre-release PostGis provider
> But i am not able to do anything
> In mapguide studio. when i try to create a new PostGis data connection i
> have no connection properties.
> There is nothing in the log file...
> In Autodesk Map 2008, when i try the same thing i got:
> Unable to create connection to provider 'OSGeo.PostGIS.3.2'
> Unable to load the FDO Provider: This application has failed to start
> because the application configuration is incorrect. Reinstalling the
> application may fix this problem.
> It seems that the postgis fdo dll is not loading
Bruno,
Most likely, you've not new Visual C++ run-time libraries in your
system. I build PostGIS provider binaries with Visual C++ 2005 + SP1, so
new vcredist package is required on end-user machine.
Here you can get it:
http://www.microsoft.com/downloads/details.aspx?FamilyID=200B2FD9-AE1A-4A14-984D-389C36F85647&displaylang=en
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-users
