[fdo-users] RE: RE: Postgis/OGR providers on Ubuntu?
Jo Cook j.cook at OXFORDARCH.CO.UK
Mon Aug 20 06:16:12 EDT 2007
Hi Traian,
Many thanks for replying. Unfortunately I think I might need a bit more of a
step-by-step guide here, because when I try and follow your instructions I
just end up with more undefined references on top of the ones I had before!
Where I am starting from is a build of fdo from svn following the
instructions (so build third party then build fdo). On top of that I have
added (both the normal and dev versions of) gdal, xalan and xerces using
aptitude, and I have checked where libgdal is (/usr/lib). I have re-built
the fdo library using make/make install, and have checked to make sure that
gdal, xerces and xalan are not in /usr/local/fdo-3.2.2/lib. When I do all of
this I end up with undefined references to xalan and xerces. If I put them
back in /fdo-3.2.2/lib then I lose those undefined references but I still
have the basic:
/tmp/cc3XlLjR.o: In function `.L313':OgrFdoUtil.cpp:(.text+0x6cb): undefined
reference to `OGRFeature::SetField(int, int, int, int, int, int, int, int)'
/tmp/cc3XlLjR.o: In function `.L310':OgrFdoUtil.cpp:(.text+0x99b): undefined
/tmp/ccn687Fv.o: In function
`OgrConnection::Close()':OgrProvider.cpp:(.text+0x83): undefined reference
to `OGRDataSource::DestroyDataSource(OGRDataSource*)'
/tmp/ccn687Fv.o: In function `__static_initialization_and_destruction_0(int,
int)':OgrProvider.cpp:(.text+0xbb4): undefined reference to `OGRRegisterAll'
/tmp/ccn687Fv.o: In function `OgrFeatureReader::GetDateTime(wchar_t
const*)':OgrProvider.cpp:(.text+0xeb0): undefined reference to
`OGRFeature::GetFieldAsDateTime(int, int*, int*, int*, int*, int*, int*,
int*)'
`OgrConnection::Open()':OgrProvider.cpp:(.text+0x177c): undefined reference
to `OGRSFDriverRegistrar::Open(char const*, int, OGRSFDriver**)'
/tmp/ccn687Fv.o: In function `OgrDataReader::GetDateTime(wchar_t
const*)':OgrProvider.cpp:(.text+0x46fd): undefined reference to
int*)'
collect2: ld returned 1 exit status
So I assume that either I am not following the instructions you've given me
correctly, or I have a version problem with ogr?
Thanks again
Jo
Traian Stanev wrote:
> To add more info to this... I just did a build of the OGR provider on
> Ubuntu (64 bit), and I got it to compile and link ok. However, I did not
> use the third party components that come with FDO. I used Synaptic to add
> xerces and xalan and cppunit and then ran the makefile for FDO rather than
> the build script. This generates libFDO linked to the already installed
> xerces.
> I also got the latest GDAL available (1.4.2) and installed that in the
> default location (/usr/local/). After that the OGR provider built without
> errors.
> To check which gdal your build is using try a command like:
> whereis libgdal
> I can try to do a 32 build using the regular build process, since this
> could be partly the reason why it's not working out for you so well... but
> that will  need more time to set up, so I can't do it immediately.
> Traian
> -----Original Message-----
> From:	fdo-users-bounces at lists.osgeo.org on behalf of Traian Stanev
> Sent:	Sat 8/18/2007 12:22 PM
> To:	FDO Users Mail List; fdo-users at lists.osgeo.org
> Cc:
> Subject:	RE: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
> What version of GDAL/OGR are you linking against? It could be finding
> older ogr libraries somewhere in the path and trying to link against them.
> May be it is linking against the GDAL that comes with FDO, which is an old
> version and will not work, since it doesn't have these API calls.
> When I compiled on Linux, I installed both GDAL and Xerces using my
> distribution's (Gentoo x64) installer rather than compile the ones that
> come with FDO. I recommend this approach -- and also remove xerces and
> gdal from the /usr/local/fdo-3.2.2/lib if they are there.
> Traian
> 	From: fdo-users-bounces at lists.osgeo.org on behalf of Jo Cook
> 	Sent: Wed 8/15/2007 11:04 AM
> 	To: fdo-users at lists.osgeo.org
> 	Cc:
> 	Subject: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
> 	OK,
> 	By including /usr/local/fdo-3.2.2/lib in LD_LIBRARY_PATH I have got rid
> of
> 	warnings, but I still have the following error:
> 	==============begin============
> 	/tmp/ccgHSqr3.o: In function `.L313':OgrFdoUtil.cpp:(.text+0x6cb):
> undefined
> int)'
> 	/tmp/ccgHSqr3.o: In function `.L310':OgrFdoUtil.cpp:(.text+0x99b):
> undefined
> int)'
> 	/tmp/ccCoNaFF.o: In function
> reference
> `OGRRegisterAll'
> 	/tmp/ccCoNaFF.o: In function `OgrFeatureReader::GetDateTime(wchar_t
> 	int*)'
> reference
> 	/tmp/ccCoNaFF.o: In function `OgrDataReader::GetDateTime(wchar_t
> 	int*)'
> 	=========end=========
> 	Any thoughts?
> 	Jo
> 	Jo Cook wrote:
> 	> Hi,
> 	> Hmm, I thought I'd sorted that, but it appears not. New error message
> from
> 	> compile.sh:
> 	> ===========begin error msg========
> 	> /usr/bin/ld: warning: libxalanMsg.so.17, needed by
> 	> /usr/local/fdo-3.2.2/lib/libFDO.so, not found (try using -rpath or
> 	> -rpath-link)
> 	> /usr/bin/ld: warning: libxerces-c.so.25, needed by
> 	> -rpath-link)
> 	> /tmp/ccs942wc.o: In function `.L313':OgrFdoUtil.cpp:(.text+0x6cb):
> 	> undefined reference to `OGRFeature::SetField(int, int, int, int, int,
> int,
> 	> int, int)'
> 	> /tmp/ccs942wc.o: In function `.L310':OgrFdoUtil.cpp:(.text+0x99b):
> int,
> 	> int, int)'
> 	> /tmp/ccXqYF0e.o: In function
> reference
> 	> `OGRRegisterAll'
> 	> /tmp/ccXqYF0e.o: In function `OgrFeatureReader::GetDateTime(wchar_t
> int*,
> 	> int*)'
> 	> reference to `OGRSFDriverRegistrar::Open(char const*, int,
> OGRSFDriver**)'
> 	> /tmp/ccXqYF0e.o: In function `OgrDataReader::GetDateTime(wchar_t
> int*,
> 	> int*)'
> 	> /usr/local/fdo-3.2.2/lib/libFDO.so: undefined reference to
> 	> `xercesc_2_5::DTDEntityDecl::getProtoType() const'
> 	> `xalanc_1_7::ProblemListener::~ProblemListener()'
> 	> `xercesc_2_5::XMLTransService::makeNewTranscoderFor(unsigned short
> const*,
> 	> xercesc_2_5::XMLTransService::Codes&, unsigned int,
> 	> xercesc_2_5::MemoryManager*)'
> 	> `xercesc_2_5::DTDEntityDecl::serialize(xercesc_2_5::XSerializeEngine&)'
> 	> `xalanc_1_7::XSLTInputSource::XSLTInputSource()'
> 	> `xercesc_2_5::XMLRefInfo::getProtoType() const'
> 	> `xercesc_2_5::XMLPlatformUtils::Terminate()'
> 	> `xercesc_2_5::InputSource::setPublicId(unsigned short const*)'
> 	> `xercesc_2_5::XMLPlatformUtils::Initialize(char const*, char const*,
> 	> xercesc_2_5::PanicHandler*, xercesc_2_5::MemoryManager*)'
> `xercesc_2_5::SAX2XMLReaderImpl::SAX2XMLReaderImpl(xercesc_2_5::MemoryManager*,
> 	> xercesc_2_5::XMLGrammarPool*)'
> 	> /usr/local/fdo-3.2.2/lib/libFDO.so: undefined reference to `typeinfo
> for
> 	> xercesc_2_5::XMLException'
> for
> 	> xercesc_2_5::BinInputStream'
> 	> `xercesc_2_5::AbstractDOMParser::adoptDocument()'
> 	> `xercesc_2_5::Base64::decode(unsigned char const*, unsigned int*,
> 	> `xercesc_2_5::BinInputStream::~BinInputStream()'
> 	> `xercesc_2_5::SAXParseException::getColumnNumber() const'
> 	> `xercesc_2_5::XMLEntityDecl::~XMLEntityDecl()'
> 	> `xercesc_2_5::DTDEntityDecl::isSerializable() const'
> 	> `xercesc_2_5::XMemory::operator delete(void*,
> `xercesc_2_5::XercesDOMParser::XercesDOMParser(xercesc_2_5::XMLValidator*,
> 	> xercesc_2_5::MemoryManager*, xercesc_2_5::XMLGrammarPool*)'
> 	> `xercesc_2_5::XMLUni::fgXercesLoadExternalDTD'
> 	> `xercesc_2_5::SAXParseException::getLineNumber() const'
> 	> `xalanc_1_7::XalanTransformer::XalanTransformer()'
> 	> `xercesc_2_5::XMLUni::fgDOMWRTFormatPrettyPrint'
> 	> `xercesc_2_5::XMLUni::fgXercesSchema'
> 	> `xercesc_2_5::XMLPlatformUtils::fgMemoryManager'
> 	> `xercesc_2_5::XMLAttDefList::serialize(xercesc_2_5::XSerializeEngine&)'
> `xalanc_1_7::XalanTransformer::setStylesheetParam(xalanc_1_7::XalanDOMString
> 	> const&, xalanc_1_7::XalanDOMString const&)'
> for
> 	> xercesc_2_5::XMLEntityDecl'
> for
> 	> xalanc_1_7::ProblemListener'
> for
> 	> xercesc_2_5::SAXParseException'
> 	> `xalanc_1_7::XalanTransformer::transform(xalanc_1_7::XSLTInputSource
> 	> const&, xalanc_1_7::XSLTInputSource const&, void*, unsigned int
> (*)(char
> 	> const*, unsigned int, void*), void (*)(void*))'
> 	> `xercesc_2_5::XMLAttDefList::getProtoType() const'
> 	> `xercesc_2_5::XMemory::operator new(unsigned int)'
> 	> `xalanc_1_7::ProblemListener::ProblemListener()'
> 	> `xercesc_2_5::SAXParseException::~SAXParseException()'
> 	> `xalanc_1_7::XalanDOMString::XalanDOMString(char const*, unsigned int)'
> 	> `xercesc_2_5::XMLRefInfo::serialize(xercesc_2_5::XSerializeEngine&)'
> 	> `xercesc_2_5::InputSource::setEncoding(unsigned short const*)'
> `xercesc_2_5::SAXParseException::SAXParseException(xercesc_2_5::SAXParseException
> 	> const&)'
> 	> `xercesc_2_5::XMemory::operator delete(void*)'
> 	> `xalanc_1_7::XalanTransformer::initialize()'
> 	> `xercesc_2_5::XMLString::release(unsigned char**)'
> 	> `xercesc_2_5::XMLString::release(char**)'
> for
> 	> xercesc_2_5::InputSource'
> 	> `xercesc_2_5::XMLChar1_0::isValidQName(unsigned short const*, unsigned
> 	> int)'
> 	> `xercesc_2_5::AbstractDOMParser::parse(char const*)'
> 	> `xercesc_2_5::InputSource::InputSource(xercesc_2_5::MemoryManager*)'
> 	> `xalanc_1_7::XalanTransformer::~XalanTransformer()'
> `xercesc_2_5::XercesDOMParser::setErrorHandler(xercesc_2_5::ErrorHandler*)'
> 	> `xercesc_2_5::Base64::encode(unsigned char const*, unsigned int,
> unsigned
> 	> int*, xercesc_2_5::MemoryManager*)'
> 	> `xercesc_2_5::XMLChar1_0::fgCharCharsTable1_0'
> 	> `xercesc_2_5::XMLRefInfo::isSerializable() const'
> 	> `xalanc_1_7::XalanDOMString::transcode() const'
> 	> `xercesc_2_5::DOMImplementationRegistry::getDOMImplementation(unsigned
> 	> short const*)'
> 	> `xercesc_2_5::XMLString::transcode(unsigned short const*)'
> 	> `xercesc_2_5::BinInputStream::BinInputStream()'
> for
> 	> xalanc_1_7::XSLTInputSource'
> 	> `xercesc_2_5::XMLString::release(unsigned short**)'
> 	> `xercesc_2_5::XMLAttDefList::isSerializable() const'
> 	> `xercesc_2_5::XMLPlatformUtils::fgTransService'
> 	> `xalanc_1_7::XalanTransformer::terminate()'
> 	> `xercesc_2_5::InputSource::~InputSource()'
> 	> `xercesc_2_5::InputSource::setSystemId(unsigned short const*)'
> for
> 	> xalanc_1_7::XSLException'
> 	> `xercesc_2_5::XMLString::transcode(char const*)'
> 	> `xercesc_2_5::XMLUni::fgXercescDefaultLocale'
> 	> `xercesc_2_5::XMemory::operator new(unsigned int,
> 	> /usr/local/fdo-3.2.2/lib/libFDO.so: undefined reference to `vtable for
> 	> `xercesc_2_5::LocalFileFormatTarget::LocalFileFormatTarget(char const*,
> 	> xercesc_2_5::MemoryManager*)'collect2: ld returned 1 exit status
> 	> =======end error msg===========
> 	> So- do I need to install libxalan and libxerces or is it just asking me
> to
> 	> link something?
> 	> Thanks
> 	> Jo
> 	>> Hi,
> 	>> Could you post the contents of the compilation shell file that you are
> 	>> using to compile the OGR provider? It should be a one line shell
> script.
> 	>> The one you are using may have the wrong location for FDO...
> 	>> FYI if you don't hear again from me till next week, it is because I
> have
> 	>> no internet where I am currently.
> 	>> Traian
> 	>>      Sent: Wed 8/15/2007 7:01 AM
> 	>>      Cc:
> 	>>      Subject: [fdo-users] Postgis/OGR providers on Ubuntu?
> 	>>      Hi All,
> 	>>      I would like to add the OGR and Postgis providers to my Ubuntu
> install
> 	>> of
> 	>>      Mapguide Open Source and would appreciate it if someone could
> give me a
> 	>>      little help with it. I have tried to install the ogr provider
> from svn,
> 	>> but
> 	>>      this failed at the beginning of the configure stage with the
> message
> 	>>      stdafx.h:3:17: error: Fdo.h: No such file or directory
> 	>>      followed by line upon line of error. I can post a log file of
> this if
> 	>> that
> 	>>      would be handy. Because the readme file with the source said that
> it
> 	>> wanted
> 	>>      gdal 1.4, and it wanted it somewhere accessible, I compiled and
> 	>> installed
> 	>>      gdal1.4.0 from source, which installed itself in
> /usr/local/share/gdal.
> 	>> My
> 	>>      fdo installation (installed as part of the mapguide installation)
> is in
> 	>>      /usr/local/fdo-3.2.2.
> 	>>      When I look at the postgis provider in svn, I can't even tell how
> I
> 	>> would go
> 	>>      about installing it!
> 	>>      I thought that another option would be to include the providers
> into the
> 	>>      checkoutsvn.sh script for the fdo build, but I don't really know
> how I
> 	>> would
> 	>>      proceed from there.
> 	>>      If anyone can give me some pointers on this I'd be extremely
> grateful as
> 	>> I
> 	>>      have a very lonely postgresql database that's simply yearning to
> be put
> 	>> on a
> 	>>      map!
> 	>>      Many thanks
> 	>>      Jo
> 	>>      View this message in context:
> http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.html#a12158992
> 	>>      Sent from the fdo-users mailing list archive at Nabble.com.
> 	>>      _______________________________________________
> 	>>      http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.html#a12163869
View this message in context: http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.html#a12233304
More information about the fdo-users mailing list
