[fdo-users] RE: RE: Postgis/OGR providers on Ubuntu?
Traian Stanev
traian.stanev at autodesk.com
Tue Aug 21 10:28:13 EDT 2007
The error you see happens during linking. This could mean that it is
compiling against headers that are a different version from the binary
it links to. So, make sure that if linking is done against
/usr/lib/libgdal, then compiling is done against OGR headers in
/usr/include/. I can't think of anything else that would cause this
problem.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
Sent: Monday, August 20, 2007 6:16 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] RE: RE: Postgis/OGR providers on Ubuntu?
Hi Traian,
Many thanks for replying. Unfortunately I think I might need a bit more
of a
step-by-step guide here, because when I try and follow your instructions
I
just end up with more undefined references on top of the ones I had
before!
Where I am starting from is a build of fdo from svn following the
instructions (so build third party then build fdo). On top of that I
have
added (both the normal and dev versions of) gdal, xalan and xerces using
aptitude, and I have checked where libgdal is (/usr/lib). I have
re-built
the fdo library using make/make install, and have checked to make sure
that
gdal, xerces and xalan are not in /usr/local/fdo-3.2.2/lib. When I do
all of
this I end up with undefined references to xalan and xerces. If I put
them
back in /fdo-3.2.2/lib then I lose those undefined references but I
still
have the basic:
/tmp/cc3XlLjR.o: In function `.L313':OgrFdoUtil.cpp:(.text+0x6cb):
undefined
reference to `OGRFeature::SetField(int, int, int, int, int, int, int,
int)'
/tmp/cc3XlLjR.o: In function `.L310':OgrFdoUtil.cpp:(.text+0x99b):
undefined
int)'
/tmp/ccn687Fv.o: In function
`OgrConnection::Close()':OgrProvider.cpp:(.text+0x83): undefined
reference
to `OGRDataSource::DestroyDataSource(OGRDataSource*)'
`__static_initialization_and_destruction_0(int,
int)':OgrProvider.cpp:(.text+0xbb4): undefined reference to
`OGRRegisterAll'
/tmp/ccn687Fv.o: In function `OgrFeatureReader::GetDateTime(wchar_t
const*)':OgrProvider.cpp:(.text+0xeb0): undefined reference to
`OGRFeature::GetFieldAsDateTime(int, int*, int*, int*, int*, int*, int*,
int*)'
`OgrConnection::Open()':OgrProvider.cpp:(.text+0x177c): undefined
reference
to `OGRSFDriverRegistrar::Open(char const*, int, OGRSFDriver**)'
/tmp/ccn687Fv.o: In function `OgrDataReader::GetDateTime(wchar_t
const*)':OgrProvider.cpp:(.text+0x46fd): undefined reference to
int*)'
collect2: ld returned 1 exit status
So I assume that either I am not following the instructions you've given
me
correctly, or I have a version problem with ogr?
Thanks again
Jo
Traian Stanev wrote:
> To add more info to this... I just did a build of the OGR provider on
> Ubuntu (64 bit), and I got it to compile and link ok. However, I did
not
> use the third party components that come with FDO. I used Synaptic to
add
> xerces and xalan and cppunit and then ran the makefile for FDO rather
than
> the build script. This generates libFDO linked to the already
installed
> xerces.
> I also got the latest GDAL available (1.4.2) and installed that in the
> default location (/usr/local/). After that the OGR provider built
without
> errors.
> To check which gdal your build is using try a command like:
> whereis libgdal
> I can try to do a 32 build using the regular build process, since this
> could be partly the reason why it's not working out for you so well...
but
> that will need more time to set up, so I can't do it immediately.
> Traian
> From: fdo-users-bounces at lists.osgeo.org on behalf of Traian Stanev
> Sent: Sat 8/18/2007 12:22 PM
> To: FDO Users Mail List; fdo-users at lists.osgeo.org
> Cc:
> Subject: RE: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
> What version of GDAL/OGR are you linking against? It could be finding
> older ogr libraries somewhere in the path and trying to link against
them.
> May be it is linking against the GDAL that comes with FDO, which is an
old
> version and will not work, since it doesn't have these API calls.
> When I compiled on Linux, I installed both GDAL and Xerces using my
> distribution's (Gentoo x64) installer rather than compile the ones
that
> come with FDO. I recommend this approach -- and also remove xerces and
> gdal from the /usr/local/fdo-3.2.2/lib if they are there.
> Traian
> From: fdo-users-bounces at lists.osgeo.org on behalf of Jo Cook
> Sent: Wed 8/15/2007 11:04 AM
> Cc:
> Subject: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
> OK,
> By including /usr/local/fdo-3.2.2/lib in LD_LIBRARY_PATH I have
got rid
> of
> warnings, but I still have the following error:
> ==============begin============
> /tmp/ccgHSqr3.o: In function
> undefined
int,
> int)'
> undefined
int,
> int)'
> /tmp/ccCoNaFF.o: In function
> reference
> `OGRRegisterAll'
int*, int*,
> int*)'
undefined
> reference
> /tmp/ccCoNaFF.o: In function `OgrDataReader::GetDateTime(wchar_t
int*, int*,
> int*)'
> =========end=========
> Any thoughts?
> Jo
> Jo Cook wrote:
> > Hi,
> > Hmm, I thought I'd sorted that, but it appears not. New error
message
> from
> > compile.sh:
> > ===========begin error msg========
> > /usr/bin/ld: warning: libxalanMsg.so.17, needed by
> > /usr/local/fdo-3.2.2/lib/libFDO.so, not found (try using
-rpath or
> > -rpath-link)
> > /usr/bin/ld: warning: libxerces-c.so.25, needed by
-rpath or
> > -rpath-link)
> > /tmp/ccs942wc.o: In function
> > undefined reference to `OGRFeature::SetField(int, int, int,
int, int,
> int,
> > int, int)'
int, int,
> int,
> > int, int)'
> > /tmp/ccXqYF0e.o: In function
undefined
> reference
> > `OGRRegisterAll'
int*,
> int*,
> > int*)'
undefined
> > reference to `OGRSFDriverRegistrar::Open(char const*, int,
> OGRSFDriver**)'
to
int*,
> int*,
> > int*)'
> > /usr/local/fdo-3.2.2/lib/libFDO.so: undefined reference to
> > `xercesc_2_5::DTDEntityDecl::getProtoType() const'
> > `xalanc_1_7::ProblemListener::~ProblemListener()'
> > `xercesc_2_5::XMLTransService::makeNewTranscoderFor(unsigned
short
> const*,
> > xercesc_2_5::XMLTransService::Codes&, unsigned int,
> > xercesc_2_5::MemoryManager*)'
`xercesc_2_5::DTDEntityDecl::serialize(xercesc_2_5::XSerializeEngine&)'
> > `xalanc_1_7::XSLTInputSource::XSLTInputSource()'
> > `xercesc_2_5::XMLRefInfo::getProtoType() const'
> > `xercesc_2_5::XMLPlatformUtils::Terminate()'
> > `xercesc_2_5::InputSource::setPublicId(unsigned short const*)'
> > `xercesc_2_5::XMLPlatformUtils::Initialize(char const*, char
const*,
> > xercesc_2_5::PanicHandler*, xercesc_2_5::MemoryManager*)'
`xercesc_2_5::SAX2XMLReaderImpl::SAX2XMLReaderImpl(xercesc_2_5::MemoryMa
nager*,
> > xercesc_2_5::XMLGrammarPool*)'
`typeinfo
> for
> > xercesc_2_5::XMLException'
`typeinfo
> for
> > xercesc_2_5::BinInputStream'
> > `xercesc_2_5::AbstractDOMParser::adoptDocument()'
> > `xercesc_2_5::Base64::decode(unsigned char const*, unsigned
int*,
> > `xercesc_2_5::BinInputStream::~BinInputStream()'
> > `xercesc_2_5::SAXParseException::getColumnNumber() const'
> > `xercesc_2_5::XMLEntityDecl::~XMLEntityDecl()'
> > `xercesc_2_5::DTDEntityDecl::isSerializable() const'
> > `xercesc_2_5::XMemory::operator delete(void*,
`xercesc_2_5::XercesDOMParser::XercesDOMParser(xercesc_2_5::XMLValidator
> > xercesc_2_5::MemoryManager*, xercesc_2_5::XMLGrammarPool*)'
> > `xercesc_2_5::XMLUni::fgXercesLoadExternalDTD'
> > `xercesc_2_5::SAXParseException::getLineNumber() const'
> > `xalanc_1_7::XalanTransformer::XalanTransformer()'
> > `xercesc_2_5::XMLUni::fgDOMWRTFormatPrettyPrint'
> > `xercesc_2_5::XMLUni::fgXercesSchema'
> > `xercesc_2_5::XMLPlatformUtils::fgMemoryManager'
`xercesc_2_5::XMLAttDefList::serialize(xercesc_2_5::XSerializeEngine&)'
`xalanc_1_7::XalanTransformer::setStylesheetParam(xalanc_1_7::XalanDOMSt
ring
> > const&, xalanc_1_7::XalanDOMString const&)'
`typeinfo
> for
> > xercesc_2_5::XMLEntityDecl'
`typeinfo
> for
> > xalanc_1_7::ProblemListener'
`typeinfo
> for
> > xercesc_2_5::SAXParseException'
`xalanc_1_7::XalanTransformer::transform(xalanc_1_7::XSLTInputSource
> > const&, xalanc_1_7::XSLTInputSource const&, void*, unsigned
int
> (*)(char
> > const*, unsigned int, void*), void (*)(void*))'
> > `xercesc_2_5::XMLAttDefList::getProtoType() const'
> > `xercesc_2_5::XMemory::operator new(unsigned int)'
> > `xalanc_1_7::ProblemListener::ProblemListener()'
> > `xercesc_2_5::SAXParseException::~SAXParseException()'
> > `xalanc_1_7::XalanDOMString::XalanDOMString(char const*,
unsigned int)'
`xercesc_2_5::XMLRefInfo::serialize(xercesc_2_5::XSerializeEngine&)'
> > `xercesc_2_5::InputSource::setEncoding(unsigned short const*)'
`xercesc_2_5::SAXParseException::SAXParseException(xercesc_2_5::SAXParse
Exception
> > const&)'
> > `xercesc_2_5::XMemory::operator delete(void*)'
> > `xalanc_1_7::XalanTransformer::initialize()'
> > `xercesc_2_5::XMLString::release(unsigned char**)'
> > `xercesc_2_5::XMLString::release(char**)'
`typeinfo
> for
> > xercesc_2_5::InputSource'
> > `xercesc_2_5::XMLChar1_0::isValidQName(unsigned short const*,
unsigned
> > int)'
> > `xercesc_2_5::AbstractDOMParser::parse(char const*)'
`xercesc_2_5::InputSource::InputSource(xercesc_2_5::MemoryManager*)'
> > `xalanc_1_7::XalanTransformer::~XalanTransformer()'
`xercesc_2_5::XercesDOMParser::setErrorHandler(xercesc_2_5::ErrorHandler
> > `xercesc_2_5::Base64::encode(unsigned char const*, unsigned
int,
> unsigned
> > int*, xercesc_2_5::MemoryManager*)'
> > `xercesc_2_5::XMLChar1_0::fgCharCharsTable1_0'
> > `xercesc_2_5::XMLRefInfo::isSerializable() const'
> > `xalanc_1_7::XalanDOMString::transcode() const'
`xercesc_2_5::DOMImplementationRegistry::getDOMImplementation(unsigned
> > short const*)'
> > `xercesc_2_5::XMLString::transcode(unsigned short const*)'
> > `xercesc_2_5::BinInputStream::BinInputStream()'
`typeinfo
> for
> > xalanc_1_7::XSLTInputSource'
> > `xercesc_2_5::XMLString::release(unsigned short**)'
> > `xercesc_2_5::XMLAttDefList::isSerializable() const'
> > `xercesc_2_5::XMLPlatformUtils::fgTransService'
> > `xalanc_1_7::XalanTransformer::terminate()'
> > `xercesc_2_5::InputSource::~InputSource()'
> > `xercesc_2_5::InputSource::setSystemId(unsigned short const*)'
`typeinfo
> for
> > xalanc_1_7::XSLException'
> > `xercesc_2_5::XMLString::transcode(char const*)'
> > `xercesc_2_5::XMLUni::fgXercescDefaultLocale'
> > `xercesc_2_5::XMemory::operator new(unsigned int,
`vtable for
`xercesc_2_5::LocalFileFormatTarget::LocalFileFormatTarget(char const*,
> > xercesc_2_5::MemoryManager*)'collect2: ld returned 1 exit
status
> > =======end error msg===========
> > So- do I need to install libxalan and libxerces or is it just
asking me
> to
> > link something?
> > Thanks
> > Jo
> >> Hi,
> >> Could you post the contents of the compilation shell file
that you are
> >> using to compile the OGR provider? It should be a one line
shell
> script.
> >> The one you are using may have the wrong location for FDO...
> >> FYI if you don't hear again from me till next week, it is
because I
> have
> >> no internet where I am currently.
> >> Traian
Cook
> >> Sent: Wed 8/15/2007 7:01 AM
> >> Cc:
> >> Subject: [fdo-users] Postgis/OGR providers on Ubuntu?
> >> Hi All,
> >> I would like to add the OGR and Postgis providers to my
Ubuntu
> install
> >> of
> >> Mapguide Open Source and would appreciate it if someone
could
> give me a
> >> little help with it. I have tried to install the ogr
provider
> from svn,
> >> but
> >> this failed at the beginning of the configure stage with
the
> message
> >> stdafx.h:3:17: error: Fdo.h: No such file or directory
> >> followed by line upon line of error. I can post a log
file of
> this if
> >> that
> >> would be handy. Because the readme file with the source
said that
> it
> >> wanted
> >> gdal 1.4, and it wanted it somewhere accessible, I
compiled and
> >> installed
> >> gdal1.4.0 from source, which installed itself in
> /usr/local/share/gdal.
> >> My
> >> fdo installation (installed as part of the mapguide
installation)
> is in
> >> /usr/local/fdo-3.2.2.
> >> When I look at the postgis provider in svn, I can't even
tell how
> I
> >> would go
> >> about installing it!
> >> I thought that another option would be to include the
providers
> into the
> >> checkoutsvn.sh script for the fdo build, but I don't
really know
> how I
> >> would
> >> proceed from there.
> >> If anyone can give me some pointers on this I'd be
extremely
> grateful as
> >> I
> >> have a very lonely postgresql database that's simply
yearning to
> be put
> >> on a
> >> map!
> >> Many thanks
> >> Jo
> >> View this message in context:
http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.h
tml#a12158992
> >> Sent from the fdo-users mailing list archive at
Nabble.com.
> >> _______________________________________________
> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
tml#a12163869
> Sent from the fdo-users mailing list archive at Nabble.com.
tml#a12233304
More information about the fdo-users
