[fdo-users] RE: RE: RE: Postgis/OGR providers on Ubuntu?
Jo Cook j.cook at OXFORDARCH.CO.UK
Wed Aug 22 04:03:14 EDT 2007
Hi Traian,
Thanks for getting back to me.
Sorry, how do I do this? (I'm still pretty new to all of this)
Jo
Traian Stanev wrote:
> The error you see happens during linking. This could mean that it is
> compiling against headers that are a different version from the binary
> it links to. So, make sure that if linking is done against
> /usr/lib/libgdal, then compiling is done against OGR headers in
> /usr/include/. I can't think of anything else that would cause this
> problem.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
> Sent: Monday, August 20, 2007 6:16 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] RE: RE: Postgis/OGR providers on Ubuntu?
> Hi Traian,
> Many thanks for replying. Unfortunately I think I might need a bit more
> of a
> step-by-step guide here, because when I try and follow your instructions
> I
> just end up with more undefined references on top of the ones I had
> before!
> Where I am starting from is a build of fdo from svn following the
> instructions (so build third party then build fdo). On top of that I
> have
> added (both the normal and dev versions of) gdal, xalan and xerces using
> aptitude, and I have checked where libgdal is (/usr/lib). I have
> re-built
> the fdo library using make/make install, and have checked to make sure
> that
> gdal, xerces and xalan are not in /usr/local/fdo-3.2.2/lib. When I do
> all of
> this I end up with undefined references to xalan and xerces. If I put
> them
> back in /fdo-3.2.2/lib then I lose those undefined references but I
> still
> have the basic:
> /tmp/cc3XlLjR.o: In function `.L313':OgrFdoUtil.cpp:(.text+0x6cb):
> undefined
> reference to `OGRFeature::SetField(int, int, int, int, int, int, int,
> int)'
> /tmp/cc3XlLjR.o: In function `.L310':OgrFdoUtil.cpp:(.text+0x99b):
> undefined
> int)'
> /tmp/ccn687Fv.o: In function
> `OgrConnection::Close()':OgrProvider.cpp:(.text+0x83): undefined
> reference
> to `OGRDataSource::DestroyDataSource(OGRDataSource*)'
> `__static_initialization_and_destruction_0(int,
> int)':OgrProvider.cpp:(.text+0xbb4): undefined reference to
> `OGRRegisterAll'
> /tmp/ccn687Fv.o: In function `OgrFeatureReader::GetDateTime(wchar_t
> const*)':OgrProvider.cpp:(.text+0xeb0): undefined reference to
> `OGRFeature::GetFieldAsDateTime(int, int*, int*, int*, int*, int*, int*,
> int*)'
> `OgrConnection::Open()':OgrProvider.cpp:(.text+0x177c): undefined
> reference
> to `OGRSFDriverRegistrar::Open(char const*, int, OGRSFDriver**)'
> /tmp/ccn687Fv.o: In function `OgrDataReader::GetDateTime(wchar_t
> const*)':OgrProvider.cpp:(.text+0x46fd): undefined reference to
> int*)'
> collect2: ld returned 1 exit status
> So I assume that either I am not following the instructions you've given
> me
> correctly, or I have a version problem with ogr?
> Thanks again
> Jo
>> To add more info to this... I just did a build of the OGR provider on
>> Ubuntu (64 bit), and I got it to compile and link ok. However, I did
> not
>> use the third party components that come with FDO. I used Synaptic to
> add
>> xerces and xalan and cppunit and then ran the makefile for FDO rather
> than
>> the build script. This generates libFDO linked to the already
> installed
>> xerces.
>> I also got the latest GDAL available (1.4.2) and installed that in the
>> default location (/usr/local/). After that the OGR provider built
> without
>> errors.
>> To check which gdal your build is using try a command like:
>> whereis libgdal
>> I can try to do a 32 build using the regular build process, since this
>> could be partly the reason why it's not working out for you so well...
> but
>> that will  need more time to set up, so I can't do it immediately.
>> Traian
>> From:	fdo-users-bounces at lists.osgeo.org on behalf of Traian Stanev
>> Sent:	Sat 8/18/2007 12:22 PM
>> To:	FDO Users Mail List; fdo-users at lists.osgeo.org
>> Cc:
>> Subject:	RE: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
>> What version of GDAL/OGR are you linking against? It could be finding
>> older ogr libraries somewhere in the path and trying to link against
> them.
>> May be it is linking against the GDAL that comes with FDO, which is an
> old
>> version and will not work, since it doesn't have these API calls.
>> When I compiled on Linux, I installed both GDAL and Xerces using my
>> distribution's (Gentoo x64) installer rather than compile the ones
> that
>> come with FDO. I recommend this approach -- and also remove xerces and
>> gdal from the /usr/local/fdo-3.2.2/lib if they are there.
>> Traian
>> 	From: fdo-users-bounces at lists.osgeo.org on behalf of Jo Cook
>> 	Sent: Wed 8/15/2007 11:04 AM
>> 	Cc:
>> 	Subject: [fdo-users] RE: Postgis/OGR providers on Ubuntu?
>> 	OK,
>> 	By including /usr/local/fdo-3.2.2/lib in LD_LIBRARY_PATH I have
> got rid
>> of
>> 	warnings, but I still have the following error:
>> 	==============begin============
>> 	/tmp/ccgHSqr3.o: In function
>> undefined
> int,
>> int)'
>> undefined
> int,
>> int)'
>> 	/tmp/ccCoNaFF.o: In function
>> reference
>> `OGRRegisterAll'
> int*, int*,
>> 	int*)'
> undefined
>> reference
>> 	/tmp/ccCoNaFF.o: In function `OgrDataReader::GetDateTime(wchar_t
> int*, int*,
>> 	int*)'
>> 	=========end=========
>> 	Any thoughts?
>> 	Jo
>> 	Jo Cook wrote:
>> 	> Hi,
>> 	> Hmm, I thought I'd sorted that, but it appears not. New error
> message
>> from
>> 	> compile.sh:
>> 	> ===========begin error msg========
>> 	> /usr/bin/ld: warning: libxalanMsg.so.17, needed by
>> 	> /usr/local/fdo-3.2.2/lib/libFDO.so, not found (try using
> -rpath or
>> 	> -rpath-link)
>> 	> /usr/bin/ld: warning: libxerces-c.so.25, needed by
> -rpath or
>> 	> -rpath-link)
>> 	> /tmp/ccs942wc.o: In function
>> 	> undefined reference to `OGRFeature::SetField(int, int, int,
> int, int,
>> int,
>> 	> int, int)'
> int, int,
>> int,
>> 	> int, int)'
>> 	> /tmp/ccXqYF0e.o: In function
> undefined
>> reference
>> 	> `OGRRegisterAll'
> int*,
>> int*,
>> 	> int*)'
> undefined
>> 	> reference to `OGRSFDriverRegistrar::Open(char const*, int,
>> OGRSFDriver**)'
> to
> int*,
>> int*,
>> 	> int*)'
>> 	> /usr/local/fdo-3.2.2/lib/libFDO.so: undefined reference to
>> 	> `xercesc_2_5::DTDEntityDecl::getProtoType() const'
>> 	> `xalanc_1_7::ProblemListener::~ProblemListener()'
>> 	> `xercesc_2_5::XMLTransService::makeNewTranscoderFor(unsigned
> short
>> const*,
>> 	> xercesc_2_5::XMLTransService::Codes&, unsigned int,
>> 	> xercesc_2_5::MemoryManager*)'
> `xercesc_2_5::DTDEntityDecl::serialize(xercesc_2_5::XSerializeEngine&)'
>> 	> `xalanc_1_7::XSLTInputSource::XSLTInputSource()'
>> 	> `xercesc_2_5::XMLRefInfo::getProtoType() const'
>> 	> `xercesc_2_5::XMLPlatformUtils::Terminate()'
>> 	> `xercesc_2_5::InputSource::setPublicId(unsigned short const*)'
>> 	> `xercesc_2_5::XMLPlatformUtils::Initialize(char const*, char
> const*,
>> 	> xercesc_2_5::PanicHandler*, xercesc_2_5::MemoryManager*)'
> `xercesc_2_5::SAX2XMLReaderImpl::SAX2XMLReaderImpl(xercesc_2_5::MemoryMa
> nager*,
>> 	> xercesc_2_5::XMLGrammarPool*)'
> `typeinfo
>> for
>> 	> xercesc_2_5::XMLException'
> `typeinfo
>> for
>> 	> xercesc_2_5::BinInputStream'
>> 	> `xercesc_2_5::AbstractDOMParser::adoptDocument()'
>> 	> `xercesc_2_5::Base64::decode(unsigned char const*, unsigned
> int*,
>> 	> `xercesc_2_5::BinInputStream::~BinInputStream()'
>> 	> `xercesc_2_5::SAXParseException::getColumnNumber() const'
>> 	> `xercesc_2_5::XMLEntityDecl::~XMLEntityDecl()'
>> 	> `xercesc_2_5::DTDEntityDecl::isSerializable() const'
>> 	> `xercesc_2_5::XMemory::operator delete(void*,
> `xercesc_2_5::XercesDOMParser::XercesDOMParser(xercesc_2_5::XMLValidator
>> 	> xercesc_2_5::MemoryManager*, xercesc_2_5::XMLGrammarPool*)'
>> 	> `xercesc_2_5::XMLUni::fgXercesLoadExternalDTD'
>> 	> `xercesc_2_5::SAXParseException::getLineNumber() const'
>> 	> `xalanc_1_7::XalanTransformer::XalanTransformer()'
>> 	> `xercesc_2_5::XMLUni::fgDOMWRTFormatPrettyPrint'
>> 	> `xercesc_2_5::XMLUni::fgXercesSchema'
>> 	> `xercesc_2_5::XMLPlatformUtils::fgMemoryManager'
> `xercesc_2_5::XMLAttDefList::serialize(xercesc_2_5::XSerializeEngine&)'
> `xalanc_1_7::XalanTransformer::setStylesheetParam(xalanc_1_7::XalanDOMSt
> ring
>> 	> const&, xalanc_1_7::XalanDOMString const&)'
> `typeinfo
>> for
>> 	> xercesc_2_5::XMLEntityDecl'
> `typeinfo
>> for
>> 	> xalanc_1_7::ProblemListener'
> `typeinfo
>> for
>> 	> xercesc_2_5::SAXParseException'
> `xalanc_1_7::XalanTransformer::transform(xalanc_1_7::XSLTInputSource
>> 	> const&, xalanc_1_7::XSLTInputSource const&, void*, unsigned
> int
>> (*)(char
>> 	> const*, unsigned int, void*), void (*)(void*))'
>> 	> `xercesc_2_5::XMLAttDefList::getProtoType() const'
>> 	> `xercesc_2_5::XMemory::operator new(unsigned int)'
>> 	> `xalanc_1_7::ProblemListener::ProblemListener()'
>> 	> `xercesc_2_5::SAXParseException::~SAXParseException()'
>> 	> `xalanc_1_7::XalanDOMString::XalanDOMString(char const*,
> unsigned int)'
> `xercesc_2_5::XMLRefInfo::serialize(xercesc_2_5::XSerializeEngine&)'
>> 	> `xercesc_2_5::InputSource::setEncoding(unsigned short const*)'
> `xercesc_2_5::SAXParseException::SAXParseException(xercesc_2_5::SAXParse
> Exception
>> 	> const&)'
>> 	> `xercesc_2_5::XMemory::operator delete(void*)'
>> 	> `xalanc_1_7::XalanTransformer::initialize()'
>> 	> `xercesc_2_5::XMLString::release(unsigned char**)'
>> 	> `xercesc_2_5::XMLString::release(char**)'
> `typeinfo
>> for
>> 	> xercesc_2_5::InputSource'
>> 	> `xercesc_2_5::XMLChar1_0::isValidQName(unsigned short const*,
> unsigned
>> 	> int)'
>> 	> `xercesc_2_5::AbstractDOMParser::parse(char const*)'
> `xercesc_2_5::InputSource::InputSource(xercesc_2_5::MemoryManager*)'
>> 	> `xalanc_1_7::XalanTransformer::~XalanTransformer()'
> `xercesc_2_5::XercesDOMParser::setErrorHandler(xercesc_2_5::ErrorHandler
>> 	> `xercesc_2_5::Base64::encode(unsigned char const*, unsigned
> int,
>> unsigned
>> 	> int*, xercesc_2_5::MemoryManager*)'
>> 	> `xercesc_2_5::XMLChar1_0::fgCharCharsTable1_0'
>> 	> `xercesc_2_5::XMLRefInfo::isSerializable() const'
>> 	> `xalanc_1_7::XalanDOMString::transcode() const'
> `xercesc_2_5::DOMImplementationRegistry::getDOMImplementation(unsigned
>> 	> short const*)'
>> 	> `xercesc_2_5::XMLString::transcode(unsigned short const*)'
>> 	> `xercesc_2_5::BinInputStream::BinInputStream()'
> `typeinfo
>> for
>> 	> xalanc_1_7::XSLTInputSource'
>> 	> `xercesc_2_5::XMLString::release(unsigned short**)'
>> 	> `xercesc_2_5::XMLAttDefList::isSerializable() const'
>> 	> `xercesc_2_5::XMLPlatformUtils::fgTransService'
>> 	> `xalanc_1_7::XalanTransformer::terminate()'
>> 	> `xercesc_2_5::InputSource::~InputSource()'
>> 	> `xercesc_2_5::InputSource::setSystemId(unsigned short const*)'
> `typeinfo
>> for
>> 	> xalanc_1_7::XSLException'
>> 	> `xercesc_2_5::XMLString::transcode(char const*)'
>> 	> `xercesc_2_5::XMLUni::fgXercescDefaultLocale'
>> 	> `xercesc_2_5::XMemory::operator new(unsigned int,
> `vtable for
> `xercesc_2_5::LocalFileFormatTarget::LocalFileFormatTarget(char const*,
>> 	> xercesc_2_5::MemoryManager*)'collect2: ld returned 1 exit
> status
>> 	> =======end error msg===========
>> 	> So- do I need to install libxalan and libxerces or is it just
> asking me
>> to
>> 	> link something?
>> 	> Thanks
>> 	> Jo
>> 	>> Hi,
>> 	>> Could you post the contents of the compilation shell file
> that you are
>> 	>> using to compile the OGR provider? It should be a one line
> shell
>> script.
>> 	>> The one you are using may have the wrong location for FDO...
>> 	>> FYI if you don't hear again from me till next week, it is
> because I
>> have
>> 	>> no internet where I am currently.
>> 	>> Traian
> Cook
>> 	>>      Sent: Wed 8/15/2007 7:01 AM
>> 	>>      Cc:
>> 	>>      Subject: [fdo-users] Postgis/OGR providers on Ubuntu?
>> 	>>      Hi All,
>> 	>>      I would like to add the OGR and Postgis providers to my
> Ubuntu
>> install
>> 	>> of
>> 	>>      Mapguide Open Source and would appreciate it if someone
> could
>> give me a
>> 	>>      little help with it. I have tried to install the ogr
> provider
>> from svn,
>> 	>> but
>> 	>>      this failed at the beginning of the configure stage with
> the
>> message
>> 	>>      stdafx.h:3:17: error: Fdo.h: No such file or directory
>> 	>>      followed by line upon line of error. I can post a log
> file of
>> this if
>> 	>> that
>> 	>>      would be handy. Because the readme file with the source
> said that
>> it
>> 	>> wanted
>> 	>>      gdal 1.4, and it wanted it somewhere accessible, I
> compiled and
>> 	>> installed
>> 	>>      gdal1.4.0 from source, which installed itself in
>> /usr/local/share/gdal.
>> 	>> My
>> 	>>      fdo installation (installed as part of the mapguide
> installation)
>> is in
>> 	>>      /usr/local/fdo-3.2.2.
>> 	>>      When I look at the postgis provider in svn, I can't even
> tell how
>> I
>> 	>> would go
>> 	>>      about installing it!
>> 	>>      I thought that another option would be to include the
> providers
>> into the
>> 	>>      checkoutsvn.sh script for the fdo build, but I don't
> really know
>> how I
>> 	>> would
>> 	>>      proceed from there.
>> 	>>      If anyone can give me some pointers on this I'd be
> extremely
>> grateful as
>> 	>> I
>> 	>>      have a very lonely postgresql database that's simply
> yearning to
>> be put
>> 	>> on a
>> 	>>      map!
>> 	>>      Many thanks
>> 	>>      Jo
>> 	>>      View this message in context:
> http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.h
> tml#a12158992
>> 	>>      Sent from the fdo-users mailing list archive at
> Nabble.com.
>> 	>>      _______________________________________________
>> 	>>      http://lists.osgeo.org/mailman/listinfo/fdo-users
> tml#a12163869
>> 	Sent from the fdo-users mailing list archive at Nabble.com.
> tml#a12233304
View this message in context: http://www.nabble.com/Postgis-OGR-providers-on-Ubuntu--tf4272057s18162.html#a12269999
More information about the fdo-users mailing list
