Re: [fdo-users] GDAL FDO provider with raster performance enhancements
robert fritz
robert-fritz at web.de
Thu Aug 23 10:25:57 EDT 2007
Frank,
thank you very much for your reply. In Studio I can create a new "Data Connection" using the GDAL provider listed in the "Select feature provider" dialog box. I put the path to the folder in the "Connection properties" (labeled as DefaultRasterFileLocation), "Test Connection" gives back a "Succesful connection". But I do not get a list of files when I click on "View data" in the "preview" pane. And I do not see any image in the layer or map preview - even if I combine the raster image layer with a sdf based "boundary" layer. The problem is - there isn't any error message - neither in Studio nor in the the server log files.
I'm not sure if I should install MG OS to test it - I think it should work with MGE 2008 too?
Regards, Robert
*Von:* FDO Users Mail List <FDO-USERS at LISTS.OSGEO.ORG>
*Gesendet:* 23.08.07 15:39:06
*An:* FDO Users Mail List <FDO-USERS at LISTS.OSGEO.ORG>
*Betreff:* Re: [fdo-users] GDAL FDO provider with raster performance enhancements
robert fritz wrote:
> Hi,
> I installed the new GDAL FDO provider with raster performance
> enhancements (http://trac.osgeo.org/fdo/wiki/FdoGdalNotes) on MGE 2008.
> When I execute the configbuilder.php an "An exception occurred in FDO
> component. FDO Provider Not Registered Exception occurred in method
> MgFdoConnectionManager.Open at line 259 in file
> c:uild_bond_areaBond_NightlyBUILD_41.3EntOSServersrcCommonManagerFdoConnectionManager.cpp
> " occurs. It seems that the function $tmpSpatialContextReader =
> $featureService->GetSpatialContexts($tmpResource, false); causes the
> message.
> I have no idea what is going wrong. I tried different raster datasets
> (tifs, png) but got the same error.
Robert,
I'm not clear on why you would be getting as far as a GetSpatialContexts()
call before hitting a "provider not registered exception" but I don't
know how the configbuilder.php is setup. Does the provider work with
MGE for displaying raster data?
The first thing I would check is that the provider is properly listed
in the providers.xml file. I believe FDO is very sensitive to getting
version numbers right in this file for instance.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
Jetzt neu! Schützen Sie Ihren PC mit McAfee und WEB.DE. 3 Monate
kostenlos testen. *http://www.pc-sicherheit.web.de/startseite/?mc=022220* [http://www.pc-sicherheit.web.de/startseite/?mc=022220]
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070823/4bb45e40/attachment.html
More information about the fdo-users
