[fdo-users] build_linux errors
Greg Boone
greg.boone at autodesk.com
Wed Dec 12 11:03:16 EST 2007
Just to clarify...
1) You have extracted all the FDO source code from the fdocore and various provider svn repositories?
2) You executed 'source ./setenvironment.sh' without issue?
3) You executed ./build_thirdparty.sh without issue?
4) Running build_linux.sh built the FDO API binaries first?
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Marc Pfister
Sent: Wednesday, December 12, 2007 12:58 AM
To: FDO Users Mail List
Subject: RE: [fdo-users] build_linux errors
Jack Lee wrote:
> FdoMessage.h is a generated file and it doesn't seem to be generated.
> Did you get any other errors?
With build_linux.sh I just get the same error for every package.
FdoMessage.h is definitely not present on my system. I assume it should have been generated by build_thirdparty.sh, but if I grep through the log of the script, there's no mention of FdoMessage anywhere.
I'm not seeing any glaring errors in build_thirdparty either.
Marc
More information about the fdo-users
