[fdo-users] FDO MySQL Defect : wrong column order
Bruno Scott
bscott at geomapgis.com
Fri Dec 28 06:09:02 EST 2007
I have created a Feature Class using the MySql FDO provider
I have added all properties in this order
KEY_1
STRING_1
INT32_1
DOUBLE_1
DATE_1
STR_CODE_1
INT_CODE_1
When i query this feature class i get back this order
DATE_1
DOUBLE_1
INT32_1
INT_CODE_1
STRING_1
STR_CODE_1
KEY_1
It seems that the provider some kind of sort the column
and it always return the primary key field last
There is also something strange with the column order when we add a geometry
column
FDO MySQL should respect the order of column creation
and return the same order when we isssue a "Select * from MyTable"
Bruno
View this message in context: http://www.nabble.com/FDO-MySQL-Defect-%3A-wrong-column-order-tp14524584s18162p14524584.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
