[fdo-users] FDO 3.1 vs 3.2
George McLean
gmclean at gorge.net
Fri Dec 28 17:21:21 EST 2007
Hello,
I am finally getting around to updating a .NET application to run in Map
2008 so I am running into some issues using the FDO 3.2 libraries. In
the code below I am using the MySQL provider to insert point objects
into a MySQL database. I get an error "Unsupported Geometry Type" for
all my points using the following code.
' Load the geometry object
Dim d(3) As Double
d(0) = BlRef.Position.X
d(1) = BlRef.Position.Y
d(2) = BlRef.Position.Z
Dim geoPoint As OSGeo.FDO.Geometry.IPoint
geoPoint = gf.CreatePoint(3, d)
Dim byteArray() As Byte
byteArray = gf.GetFgf(geoPoint) ' gf.GetAgf(geoPoint)
fdoGeoData = New OSGeo.FDO.Expression.GeometryValue(byteArray)
fdoPropertyValue = New
OSGeo.FDO.Commands.PropertyValue("geometry", fdoGeoData)
fdoValueCollectionIndex = fdoPropertyValues.Add(fdoPropertyValue)
' Insert into FDO
Dim fdoFeatureReader As osgeo.Fdo.Commands.Feature.IFeatureReader
Try
fdoFeatureReader = fdoInsertObject.Execute()
fdoTrans.Commit()
fdoFeatureReader.Dispose()
This code was working fine using the appropriate FDO 3.1 libraries. I
have similar code for loading LineString features that also fails in
3.2. Any suggestions on how to debug this?
Thanks
George McLean
More information about the fdo-users
