[fdo-users] FDO 3.2 SHP insertion issue with Mapguide 6.5
Ytse
bill_gfr at yahoo.fr
Mon Feb 26 15:26:22 EST 2007
Ok first of all thank you all for your quick answers
I've successfully added 1 features after deleting the SSI file, there might be something about it, but it has failed for all other attemps (of course I'm rebuilding the shp from scratch each time I try a new test) .
Deleting the .idx file doesn't seem to have any effect.
I'll give it a closer look tomorrow but it's too much for me today (its 9.30PM for me)
----- Message d'origine ----
De : Robert Bray <rbray at robertbray.net>
À : Dan Stoica <dan.stoica at autodesk.com>
Cc : Robert Fortin <robert.fortin at autodesk.com>; Ytse <bill_gfr at yahoo.fr>; fdo-users at lists.osgeo.org
Envoyé le : Lundi, 26 Février 2007, 17h11mn 50s
Objet : Re: [fdo-users] FDO 3.2 SHP insertion issue with Mapguide 6.5
Actually the .ssi file is MG 6.5 spatial index for SHP. Pierre, please
try this suggestion and let me know if it works.
Bob
Dan Stoica wrote:
> No, the .ssi file is the ESRI's index file.
> The spatial index file is .idx. This one gets rebuild a reconnect time in case there is a mismatch between the number of geometries in .shp and the number of objects in .idx.
> Dan.
> -----Original Message-----
> From: Robert Fortin
> Sent: Monday, February 26, 2007 10:46 AM
> To: Ytse; Dan Stoica; fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] FDO 3.2 SHP insertion issue with Mapguide 6.5
> Pierre,
> I spoke with MG team and they suggested to delete the .ssi file (the MG 6.5 spatial index) after updating the SHP file. It should be rebuild by MG next time the SHP file is accessed. The .ssi file is not maintained by the SHP provider.
> RF
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Ytse
> Sent: Monday, February 26, 2007 4:18 AM
> To: Dan Stoica; fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO 3.2 SHP insertion issue with Mapguide 6.5
> Hi Dan and everyone, I'm sorry to bother you once again but I'm in a desperate need of solution about this issue
> When I add a feature object to my feature class using FDO 3.2 I can read it again with FDO or ArcView, but Mapguide Viewer and Author 6.5 won't detect it. There might actually be an issue with the index as when I delete features (thus recompressing and reindexing the file), my new fetures will then appear.
> You said you were able to see it in MAP, I guess you were talking about 2007 Could you or anyone else try to have a look at why Map 6.5 can't detect it ? I mean even if I have to do whatever binary operation to make it work, I have to correct this for the end of the week, that's my final deadline.
> If I can't make it I simply can't release my work.
> Thank you
> Pierre
> De : Dan Stoica <dan.stoica at autodesk.com> À : Ytse <bill_gfr at yahoo.fr> Envoyé le : Jeudi, 25 Janvier 2007, 17h49mn 44s Objet : RE: RE : : RE: [fdo-users] SHP modifications issue
> We are in Ottawa, Canada.
> Your SHP files look good in MAP. I can see the extra geometry added, with no attributes.
> "was there any other way of performing this task?"
> Nothing I can think of. In general, you cannot alter the schema of a class which contain data.
> Dan.
> From: Ytse [mailto:bill_gfr at yahoo.fr]
> Sent: Thursday, January 25, 2007 4:21 AM
> To: Dan Stoica
> Subject: RE : : RE: [fdo-users] SHP modifications issue
> Where are you guys working, by the way ?
> My french contact at Autodesk has an email address that finishes by @eur.autodesk.com and you don't :)
> Back to my insertion issue, you'll find two files attached to this mail :
> - shp_1.zip contains one featureclass that I have imported from the french ministry for agriculture and recreated so that I've been able to add a column to create the link with my data (I have not found how to alter a feature class that already contains data so I decided to write a piece of code to duplicate a structure, was there any other way of performing this task ?)
> - shp_2.zip contains the same file with one additional feature (the last one). I've inserted this feature using IInsert and specifying only two properties, the geometric property and the key link to my database, "ID_EXP" (do I have to explicitely set all other columns to an empty value ?)
> If you find something that would be very nice
> ___________________________________________________________________________
> Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions !
> Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses http://fr.answers.yahoo.com
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
