[fdo-users] MySQL definition
George McLean
gmclean at gorge.net
Tue Jun 12 13:18:17 EDT 2007
Mateusz Loskot wrote:
> George McLean wrote:
>> Is there any documentation on what values should be in the tables
>> starting with f_ (appears to be Metadata) in a MySQL database? I am
>> trying to build a MySQL database from scratch using a working database
>> as a template but I am still getting generic errors like 'Internal
>> Error' when trying top access records through the .NET API. My code
>> works fine against a the database I am using as a template. I have not
>> been able to find it on the fdo.osgeo.org site.
>> Any suggestions would be appreciated.
> George,
> Here you can find SQL scripts with definition of FDO metaschema:
> http://trac.osgeo.org/fdo/browser/trunk/Providers/GenericRdbms/com
> You can find there default values for most of properties.
> Cheers
Mateusz,
Thanks, this looks like it will be helpful in a lot of ways. It turns
out my biggest problem was case sensitivity in column and attribute
names! It is always something simple once you figure it out.
Thanks again,
George
More information about the fdo-users
