[fdo-users] King.Oracle 0.7.0 - important improvements in stability
Haris Kurtagic haris at sl-king.com
Fri Jun 15 09:38:56 EDT 2007
new version of King.Oracle 0.7.0 provider is available at
www.sl-king.com/fdooracle
It is important release regarding stability of provider.
*	Solved issue with multithreading support
	Provider stopped responding in some cases like hitting refresh
map while map is already refreshing.
*	Support for concurrent multi-user Insert/Update/Delete
	In case of concurrent edits trough provider
*	Support for selecting points from "KingFdoClass"
	Added support for selecting points if points are created from
x,y,z numeric columns
*	Build with Oracle 10.2.0.3
	Build with new version of Oracle client files. Should work with
older client (10.2.0.1 ) also.
Haris
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20070615/0f28cc1c/attachment.html
More information about the fdo-users mailing list
