[fdo-users] RE: Autocad Map, FDO layer refresh
dfarina at geomap
damien.farina at wanadoo.fr
Tue Jun 19 04:15:26 EDT 2007
Thk u for your response. You're right, that's the exact behaviour I would
like to reproduce by code. ForceRefresh activates a layer update after the
user (or an event?) has activated a map update, as it is described in the
documentation.
So the problems remains the same: how to force a map update by code? Is
there an exposed Geospation API (or maybe an Object ARX solution)?
bradgisoklah wrote:
> Not sure about through the api. but in GUI go to the map display tab in
> the
> Task pane. or display manager in 2008. and select the layer you want to
> refresh and right click.
> I'm not at my install right now or I would try to find out what the actual
> command is.
> Brad
> Hi folks ;-)
> I'm a bit confused: how can i refresh an Autocad Map FDO layer (Oracle
> connection). I've searched in the Geospatial and other Autocad
> documentations, and i'm not able to find an exposed API for that. Is there
> a
> way to refresh the map as in Mapguide? The only way i've found is to
> remove/rebuild the corresponding layer, but it's not really a clean
> process!
> So if someone has already been confronted with that, and has a solution or
> have some resources to point me to... I know there's a way to force a
> layer
> refresh when a new map update is invoked (MgLayer ForceRefresh). How to
> force a map update?
> Thank you in advance
> http://www.nabble.com/Autocad-Map%2C-FDO-layer-refresh-tf3938789s18162.html#a11171371
> Sent from the fdo-users mailing list archive at Nabble.com.
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> _________________________________________________________________
> Need a break? Find your escape route with Live Search Maps.
> http://maps.live.com/default.aspx?ss=Restaurants~Hotels~Amusement%20Park&cp=33.832922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=1&FORM=MGAC01
View this message in context: http://www.nabble.com/Autocad-Map%2C-FDO-layer-refresh-tf3938789s18162.html#a11190363
More information about the fdo-users
