[fdo-users] RE: Unable to test PostGis provider
Bruno Scott
bscott at geomapgis.com
Wed Jun 27 04:43:51 EDT 2007
Hi Jason
I have already a Visual studio 2005 sp1 on my pc
and Depends warns about a missing dll " DWMAPI.DLL "
and it shows these messages
Error: The Side-by-Side configuration information for "c:\program
files\mapguideopensource\server\bin\fdo\POSTGISPROVIDER.DLL" contains
errors. This application has failed to start because the application
configuration is incorrect. Reinstalling the application may fix this
problem (14001).
files\mapguideopensource\server\bin\fdo\POSTGISOVERRIDES.DLL" contains
problem (14001).
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
I think DWMAPI.DLL is a vista dll, but as it is a delay loaded one it
should not be required.
I've run depends on other fdo provider, like MySql or KingOracle
All of them warns about this missing dll. As these providers works fine, the
error is somewhere else
JasonBirch wrote:
> Have you installed the MS C++ Runtime SP1?
> <http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-
> 4A14-984D-389C36F85647>
> If that doesn't work (after a reboot) run depends.exe on the PostGIS
> provider DLL and see if it's having difficulties locating anything.
> http://www.dependencywalker.com/
> Finally, I wonder if there were changes in libpq.dll between the version
> that Mateusz is using and the one you are.
> Jason
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Tuesday, June 26, 2007 07:01
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Unable to test PostGis provider
> Hi all
> i'm trying to test the new pre-release PostGis provider But i am not
> able to do anything
> In mapguide studio. when i try to create a new PostGis data connection
> i have no connection properties.
> There is nothing in the log file...
> In Autodesk Map 2008, when i try the same thing i got:
> Unable to create connection to provider 'OSGeo.PostGIS.3.2'
> Unable to load the FDO Provider: This application has failed to start
> because the application configuration is incorrect. Reinstalling the
> application may fix this problem.
> It seems that the postgis fdo dll is not loading
> My configuration
> Windows XP sp2
> PostGresSql 8.2.4 with PostGis 1.2.1
> Mapguide Opensource 1.2 RC1
> MapGuide Studio 2008 beta 1
> Autodesk Map 2008
> FDO PostGIS provider, build 3171
> Path to postgreSQL/bin is in the first directory in the PATH Environment
> variable fdo dll are well copied in the fdo directory Provider.xml is
> well configured
> So i'm a bit stucked
> I really like to test this provider
> Bruno Scott
> http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.ht
> ml#a11306259
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.html#a11320582
More information about the fdo-users
