[fdo-users] RE: Unable to test PostGis provider
Bruno Scott
bscott at geomapgis.com
Wed Jun 27 05:01:08 EDT 2007
The providers.xml files on the matheus site shows a fdo version 3.2.0.0
Is it build with this fdo version?
We use fdo internally in c++ program and we had problem
making fdo 3.2.2 and 3.2.0 living together!
could it be the problem?
JasonBirch wrote:
> Have you installed the MS C++ Runtime SP1?
> <http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-
> 4A14-984D-389C36F85647>
> If that doesn't work (after a reboot) run depends.exe on the PostGIS
> provider DLL and see if it's having difficulties locating anything.
> http://www.dependencywalker.com/
> Finally, I wonder if there were changes in libpq.dll between the version
> that Mateusz is using and the one you are.
> Jason
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Tuesday, June 26, 2007 07:01
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Unable to test PostGis provider
> Hi all
> i'm trying to test the new pre-release PostGis provider But i am not
> able to do anything
> In mapguide studio. when i try to create a new PostGis data connection
> i have no connection properties.
> There is nothing in the log file...
> In Autodesk Map 2008, when i try the same thing i got:
> Unable to create connection to provider 'OSGeo.PostGIS.3.2'
> Unable to load the FDO Provider: This application has failed to start
> because the application configuration is incorrect. Reinstalling the
> application may fix this problem.
> It seems that the postgis fdo dll is not loading
> My configuration
> Windows XP sp2
> PostGresSql 8.2.4 with PostGis 1.2.1
> Mapguide Opensource 1.2 RC1
> MapGuide Studio 2008 beta 1
> Autodesk Map 2008
> FDO PostGIS provider, build 3171
> Path to postgreSQL/bin is in the first directory in the PATH Environment
> variable fdo dll are well copied in the fdo directory Provider.xml is
> well configured
> So i'm a bit stucked
> I really like to test this provider
> Bruno Scott
> http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.ht
> ml#a11306259
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Unable-to-test-PostGis-provider-tf3982578s18162.html#a11320831
More information about the fdo-users
