[fdo-users] MySQL > Versions greater than 5.0.22
Robert Fritz
robert-fritz at WEB.DE
Wed May 9 05:38:20 EDT 2007
Hello,
i installed MySQL 5.0.37 and it seems that the FDO provider by Autodesk for
Map 2007 and Map 2008 dooes not work properly with this version of MySql.
I can connect to the database and create a datastore (using the
FdoUserManager), but the mysql-service is terminated abruptly if I try to
create a schema or to use the bulk-copy feature of Map.
As I have just seen on the Autodesk web-site Map 2007/2008 requires MySQL
5.0.22, but I have also tried version 5.0.27 and it seems to work.
Is there anyone who can confirm problems using version 5.0.37? If so, does
anyone know why?
Regards,
Robert
View this message in context: http://www.nabble.com/MySQL-%3E-Versions-greater-than-5.0.22-tf3714732s18162.html#a10391195
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
