[fdo-users] MySQL > Versions greater than 5.0.22
BLeeStein bleestein at gmail.com
Wed May 9 13:32:54 EDT 2007
We have been having issues connecting to ArcSDE 9.2 with Map 3D 2008. I have
been told, and heard, that AutoCAD Map 3D 2008 can not work with ArcSDE 9.2.
I have been told that ArcSDE 9.2 and Map 3D 2007 is not supposed to work
either, however we have been up and running with both for over 8 months.
Currently we are using MS SQL 2000. I have noticed more often then not, the
few people that can run AutoCAD Map 3D 2008 and ArcSDE 9.2 are using Oracle.
For what it is worth, I have been told that sometime later this summer Map
3D 2008 and ArcSDE 9.2 will be able to work effectively.
-Brian
Robert Fritz wrote:
> Hello,
> i installed MySQL 5.0.37 and it seems that the FDO provider by Autodesk
> for Map 2007 and Map 2008 dooes not work properly with this version of
> MySql.
> I can connect to the database and create a datastore (using the
> FdoUserManager), but the mysql-service is terminated abruptly if I try to
> create a schema or to use the bulk-copy feature of Map.
> As I have just seen on the Autodesk web-site Map 2007/2008 requires MySQL
> 5.0.22, but I have also tried version 5.0.27 and it seems to work.
> Is there anyone who can confirm problems using version 5.0.37? If so, does
> anyone know why?
> Regards,
> Robert
View this message in context: http://www.nabble.com/MySQL-%3E-Versions-greater-than-5.0.22-tf3714732s18162.html#a10399159
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
