[fdo-users] Problem with C++ application with OGR provider
Bruno Scott
bscott at geomapgis.com
Fri Nov 23 11:16:19 EST 2007
I have attached the source of the app
it is very small.
the only thing you have to do is to change the
"C++ Additional include directories" and "Linker Additional librairy
directories"
to make it point to the fdo directory
when you run the apps, it must also find the fdo dlls, you can set the
working directory
or you can put the fdo directory in the path, you know that anyway.
The first thing the app does is to get the list of all providers and fills a
dropdown with them.
When you select a provider it fills the connection properties. It work fine
for all of the provider
except for OGR as explained before.
Thanks a lot for your help
Bruno
gregboone wrote:
> Can you send me the app? I will try it and see what I find.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Friday, November 23, 2007 5:34 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Problem with C++ application with OGR provider
> I have a small MFC C++ application builded with Visual studio 2005
> I successfully use it with all osgeo provider ecept for OGR
> I compile against the fdo 3.2.2 binaries and i use the ogr provider 3.2.2
> binary
> As soon as a try to connect to the ogr provider
> FdoPtr<FdoIConnection> connectionPtr;
> static IConnectionManager* pConnectionManager =
> NULL;
> pConnectionManager = FdoFeatureAccessManager::GetConnectionManager();
> connectionPtr =
> pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
> I got this message in visual studio
> 'FDLWizard.exe': Loaded OGRProvider.dll', No symbols loaded.
> First-chance exception at 0x76df3baf in FDLWizard.exe: 0xC0000139:
> Entry
> Point Not Found.
> 'FDLWizard.exe': Unloaded OGRProvider.dll'
> And it finnaly throw an exception
> Unable to load the FDO Provider: The specified procedure could not be
> found.
> Someone has a idea?
> Bruno
> http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13909997
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
http://www.nabble.com/file/p13914897/FDODLG.zip FDODLG.zip
View this message in context: http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13914897
More information about the fdo-users
