[fdo-users] Problem with C++ application with OGR provider
Traian Stanev
traian.stanev at autodesk.com
Fri Nov 23 12:00:30 EST 2007
That explains why it works with fdo2fdo.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Friday, November 23, 2007 11:59 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
> fdo2fdo uses its own fdo dll, they have version 3.2.0.0
> Traian Stanev wrote:
> > Does your fdo2fdo use an FDO.dll that is local to its exe directory?
> What
> > version is that dll if it exists?
> > Traian
> >> Sent: Friday, November 23, 2007 11:26 AM
> provider
> >> i used ListDlls.exe to show what dlls are loaded with by my apps and
> it
> >> shows
> >> the good directory.
> >> In this directory all fdo dlls are have version 3.2.2.65
> >> except for xalan,xercess and gdal of course, that are not fdo dlls.
> >> OGRProvider.dll does not show any file version :(
> >> > Looks like some of your dlls are 3.2.1 and others are 3.2.2.
> >> > The signature of FdoIDisposable::Release was changed between those
> >> two
> >> > releases.
> >> > Traian
> >> >> Sent: Friday, November 23, 2007 11:00 AM
> >> provider
> >> >> Depends shows that in FDOCOMMON.DLL
> ?Release at FdoIDisposable@@QAEHXZ
> >> is
> >> >> missing
> >> >> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo
> >> connect
> >> >> without errors.
> >> >> So i must do something wrong.
> >> >> > It means it couldn't find the function CreateConnection() in
> the
> >> >> provider
> >> >> > dll. I don't remember whether I compiled the 3.2.2 OGR binary
> with
> >> VS
> >> >> SP1
> >> >> > or not and whether that would make a difference. It's worth it
> to
> >> use
> >> >> > depends.exe to check if the provider is missing any
> dependencies.
> >> >> > Traian
> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg
> Boone
> >> >> > Sent: Friday, November 23, 2007 10:00 AM
> >> >> > To: FDO Users Mail List
> >> >> provider
> >> >> > Can you send me the app? I will try it and see what I find.
> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno
> >> Scott
> >> >> > Sent: Friday, November 23, 2007 5:34 AM
> >> >> > Subject: [fdo-users] Problem with C++ application with OGR
> >> provider
> >> >> > I have a small MFC C++ application builded with Visual studio
> 2005
> >> >> > I successfully use it with all osgeo provider ecept for OGR
> >> >> > I compile against the fdo 3.2.2 binaries and i use the ogr
> >> provider
> >> >> 3.2.2
> >> >> > binary
> >> >> > As soon as a try to connect to the ogr provider
> >> >> > FdoPtr<FdoIConnection> connectionPtr;
> >> >> > static IConnectionManager* pConnectionManager
> >> >> > NULL;
> >> >> > pConnectionManager =
> >> >> FdoFeatureAccessManager::GetConnectionManager();
> >> >> > connectionPtr =
> >> >> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
> >> >> > I got this message in visual studio
> >> >> > 'FDLWizard.exe': Loaded OGRProvider.dll', No symbols
> loaded.
> >> >> > First-chance exception at 0x76df3baf in FDLWizard.exe:
> >> >> 0xC0000139:
> >> >> > Entry
> >> >> > Point Not Found.
> >> >> > 'FDLWizard.exe': Unloaded OGRProvider.dll'
> >> >> > And it finnaly throw an exception
> >> >> > Unable to load the FDO Provider: The specified procedure
> could
> >> >> not be
> >> >> > found.
> >> >> > Someone has a idea?
> >> >> > Bruno
> >> >> > View this message in context:
> >> >> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-
> OGR-
> >> >> provider-tf4860799s18162.html#a13909997
> >> >> > Sent from the fdo-users mailing list archive at Nabble.com.
> >> >> > _______________________________________________
> >> >> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> >> >> View this message in context: http://www.nabble.com/Problem-with-
> >> >> C%2B%2B-application-with-OGR-provider-
> tf4860799s18162.html#a13914578
> >> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915066
> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915245
More information about the fdo-users
