[fdo-users] Problem with C++ application with OGR provider
Bruno Scott bscott at geomapgis.com
Fri Nov 23 12:15:23 EST 2007
Got it working.
i've downloaded the 3.2.1 FDO binaries + OGR 3.2.1 and it works
Even if my app is compiled with the 3.2.2 FDO library
There must be something wrong with the 3.2.2 binaries
i am pretty sure to have compile everything with that 3.2.2 versions and use
ogr version 3.2.2
i will double check and tell you
Thanks
Traian Stanev wrote:
> That explains why it works with fdo2fdo.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>> Sent: Friday, November 23, 2007 11:59 AM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
>> fdo2fdo uses its own fdo dll, they have version 3.2.0.0
>> > Does your fdo2fdo use an FDO.dll that is local to its exe directory?
>> What
>> > version is that dll if it exists?
>> > Traian
>> >> Sent: Friday, November 23, 2007 11:26 AM
>> provider
>> >> i used ListDlls.exe to show what dlls are loaded with by my apps and
>> it
>> >> shows
>> >> the good directory.
>> >> In this directory all fdo dlls are have version 3.2.2.65
>> >> except for xalan,xercess and gdal of course, that are not fdo dlls.
>> >> OGRProvider.dll does not show any file version :(
>> >> > Looks like some of your dlls are 3.2.1 and others are 3.2.2.
>> >> > The signature of FdoIDisposable::Release was changed between those
>> >> two
>> >> > releases.
>> >> > Traian
>> >> >> Sent: Friday, November 23, 2007 11:00 AM
>> >> provider
>> >> >> Depends shows that in FDOCOMMON.DLL
>> ?Release at FdoIDisposable@@QAEHXZ
>> >> is
>> >> >> missing
>> >> >> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo
>> >> connect
>> >> >> without errors.
>> >> >> So i must do something wrong.
>> >> >> > It means it couldn't find the function CreateConnection() in
>> the
>> >> >> provider
>> >> >> > dll. I don't remember whether I compiled the 3.2.2 OGR binary
>> with
>> >> VS
>> >> >> SP1
>> >> >> > or not and whether that would make a difference. It's worth it
>> to
>> >> use
>> >> >> > depends.exe to check if the provider is missing any
>> dependencies.
>> >> >> > Traian
>> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg
>> Boone
>> >> >> > Sent: Friday, November 23, 2007 10:00 AM
>> >> >> > To: FDO Users Mail List
>> >> >> provider
>> >> >> > Can you send me the app? I will try it and see what I find.
>> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno
>> >> Scott
>> >> >> > Sent: Friday, November 23, 2007 5:34 AM
>> >> >> > Subject: [fdo-users] Problem with C++ application with OGR
>> >> provider
>> >> >> > I have a small MFC C++ application builded with Visual studio
>> 2005
>> >> >> > I successfully use it with all osgeo provider ecept for OGR
>> >> >> > I compile against the fdo 3.2.2 binaries and i use the ogr
>> >> provider
>> >> >> 3.2.2
>> >> >> > binary
>> >> >> > As soon as a try to connect to the ogr provider
>> >> >> >     FdoPtr<FdoIConnection>             connectionPtr;
>> >> >> >     static IConnectionManager*         pConnectionManager
>> >> >> > NULL;
>> >> >> >     pConnectionManager =
>> >> >> FdoFeatureAccessManager::GetConnectionManager();
>> >> >> >     connectionPtr =
>> >> >> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
>> >> >> > I got this message in visual studio
>> >> >> >     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols
>> loaded.
>> >> >> >     First-chance exception at 0x76df3baf in FDLWizard.exe:
>> >> >> 0xC0000139:
>> >> >> > Entry
>> >> >> > Point Not Found.
>> >> >> >     'FDLWizard.exe': Unloaded OGRProvider.dll'
>> >> >> > And it finnaly throw an exception
>> >> >> >     Unable to load the FDO Provider: The specified procedure
>> could
>> >> >> not be
>> >> >> > found.
>> >> >> > Someone has a idea?
>> >> >> > Bruno
>> >> >> > View this message in context:
>> >> >> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-
>> OGR-
>> >> >> provider-tf4860799s18162.html#a13909997
>> >> >> > Sent from the fdo-users mailing list archive at Nabble.com.
>> >> >> > _______________________________________________
>> >> >> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>> >> >> View this message in context: http://www.nabble.com/Problem-with-
>> >> >> C%2B%2B-application-with-OGR-provider-
>> tf4860799s18162.html#a13914578
>> >> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915066
>> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915245
View this message in context: http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915798
More information about the fdo-users mailing list
