[fdo-users] PostGIS Provider
Gwenael Bachelot
gwenael.bachelot at eur.autodesk.com
Tue Sep 11 10:34:48 EDT 2007
Mateusz,
Ok, thanks for your answer.
What URL should I post for downloading the PostGIS OSGeo binaries ?
Can I post http://www.jasonbirch.com/fdopostgis/fdopostgis_alpha.zip ?
Or could this binairy be posted on OSGeo Web site, even if it's in early
stage ?
Cordialement,
Gwenael
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: mardi 11 septembre 2007 15:45
To: FDO Users Mail List
Subject: Re: [fdo-users] PostGIS Provider
Gwenael Bachelot wrote:
> I would like to discuss on the native FDO PostGIS provider developed
> by Mateusz Loskot. I know there are binaries for release 3171 (april
> 2007), and also other binaries provided recently by Jason Birch
> recently.
Gwenael,
This old binaries were prepared by me, Jason and Haris prepared new
binaries. My binaries are built using VC++ 2005 + SP1 and the SP1 makes
problems for Jason and others. Unfortunately, I can not remove SP1 from
my installation.
> I tested these binaries on Map 3D 2008. I installed the VC++ package,
> and add the postgres needed DLLs (found thanks to Depends) to
> FDO\Bin. Read works and I can check out features. But when I try to
> check in modified features, Map 3D crashes.
A 1-2 weeks ago, I was trying to download latest Map 3D but without any
success. I'm getting message that there is no binary prepared for my
location (geographical) :-)
I have to confess that because of Jason needs the provider tested with
MapGuide, and due to my current time limitations, I dropped testing with
Map 3D for a while and focused on MapGuide only.
Second, yes, there is some issue with geometries check-in, only OGC (2D)
geometries can be inserted/updated for now.
> My understanding is that the PostGIS provider is an ongoing
> development.
Yes, this is ongoing development, however I've been very busy with
my other activities recently.
Current version is the very first release of the provider. This is not a
small piece of software, so it needs time for polishing, fixing, etc.
Generally, I will continue work on the provider as my time permits,
as I'm a volunteer contributor, but I can assure that at first place,
I'll do my best to fix bugs in currently available operations.
> But I would like to know if writing (updating geometries and
> attributes) is in the scope ?
Yes, it is.
So far, I've tested only simple cases like:
http://svn.refractions.net/fdopostgis/trunk/Samples/insert_command/inser
t_command.cpp
> Finally, I write an official Autodesk blog (again in French :-) at
> http://blogs.autodesk.com/geospatialfrance, and would like to post on
> this native provider.
Great!
> There is a lot of interest for PostGIS in France, and there could be
> some more testers after such a post. Is it too early to post on this
> provider ?
My personal opinion is, not it's not too early.
The provider is out and usable, but there are hundreds of operations
implemented and clearly it's not surprising there are still some issues,
trivial as well as crucial.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
