[fdo-users] New FDO Provider and using it in Map 3D
Robert Fortin
robert.fortin at autodesk.com
Tue Sep 11 17:50:31 EDT 2007
Hi Piet!
You could have expected the Map FDO Data Connect Dialog to look for the
properties IsPropertyFileName or IsPropertyFilePath from the
IPropertyDictionary interface to figure out if a connection property is
a file or a path and, base on that, show proper control to select either
a file or a path. But it is not the case! The default dialog that you
see doesn't make use of those properties.
BUT There is a solution to your problem: define a custom connection
control specific to your provider that would show into the Data connect
dialog. It is documented in the document help/sdk.dev.net.gis.chm
under Map install path. Look for Data Connect and follow the
instructions.
To help you get started, I have attached a sample that work with the SDF
provider renamed to OSGeo.MYSDF.3.2. Just update the reference to the
FDO, Autodesk and Map dlls and build it. Then put the dll under
<Map>/Plugins/DataConnect. Edit the providers.xml file and change or
create a copy of the SDF info and change the name to
<Name>OSGeo.MYSDF.3.2</Name>.
After that, when you start Map, a special UI will let you pick the name
of an SDF file by selecting the MYSDF provider.
Hope it helps.
RF
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Piet Bibber
Sent: Tuesday, September 11, 2007 5:20 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] New FDO Provider and using it in Map 3D
I have just created a new FDO Provider (supporting Nen1878) and
struggling
with 2 items:
1) the icon in the 'data connect'-dialog indicates a database, yet the
GetProviderDatastoreType returns FdoProviderDatastoreType_File
1a) what do I need to implement to get the browse for file and browse
for
directory buttons?
2) The Geometry column shows a 0 (zero) for Geometric Types, albeit I
return
a 'FdoGeometryType_Point' primitive in CreateCachedGeometry (called by
'virtual FdoByteArray* GetGeometry (FdoString* identifier)')
extract:
FdoGeometryType fdoGeomType = FdoGeometryType_Point;
FdoInt32 dimensionality = FdoDimensionality_XY;
FdoInt32 numPointOrds = 2; // Always 2. (No Z or M)
FdoInt32 numPositions = 1;
fgfByteArray->Clear();
fgfByteArray = FdoByteArray::Append(fgfByteArray, sizeof(fdoGeomType),
(FdoByte *) &fdoGeomType);
DoublePoint dp(0.,0.);
numBytesForOrdinates = numPointOrds * sizeof(double) * 1;
sizeof(dimensionality),
(FdoByte *) &dimensionality );
fgfByteArray = FdoByteArray::Append(fgfByteArray, numBytesForOrdinates,
(FdoByte *)&dp );
Q1: When is the Geometric Type set? During schema creation or when
passing
the geometry (I think the latter)
Thanks up front
// Piet
View this message in context:
http://www.nabble.com/New-FDO-Provider-and-using-it-in-Map-3D-tf4421295s
18162.html#a12610933
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
Type: application/x-zip-compressed
Desc: MySDFPlugin.zip
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20070911/d2dcf5e7/MySDFPlugin.bin
More information about the fdo-users
