[fdo-users] RE: RE: Unicode (nvarchar) support for MS SQL Server
Maksim Sestic
max at geoinova.com
Sat Sep 15 06:07:57 EDT 2007
I also run Google search on that topic and got equal results. Alas, I have no
idea how to implement proposed unicode_string database property change :-)
Is this a property being set during database creation, or it's possible to
apply it somehow upon existing dataset?
Here are some sources explaining what database property to set, but they
don't say _how_ to do it:
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Language_support_in_the_geodatabase&anchor=nlsss
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=About_data_types
But that's almost all on that. Brad, do you also need to set that property
within Oracle datastore to be able to keep unicode strings in it?
Regards,
Maksim Sestic
bradgisoklah wrote:
> I just did this on google and there may be something there to help you. I
> am an oracle user so don't know much about mssqlsrv.
> Brad
View this message in context: http://www.nabble.com/Unicode-%28nvarchar%29-support-for-MS-SQL-Server-tf4422980s18162.html#a12689020
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
