[fdo-users] FDO, Map 2007 and MySQL Server
Jack Lee jack.lee at autodesk.com
Fri Sep 28 07:38:47 EDT 2007
MySql 5.0.45 is not supported. You should do an install of 5.0.22.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Friday, September 28, 2007 7:30 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO, Map 2007 and MySQL Server
Hi all,
I'm just testing Map 2007 FDO connectivity with latest MySQL Server
release.
Naturally, it didn't went smooth :-) Here's my list of "prerequisites":
- Latest MySQL Community Server 5.0 (5.0.45)
- Autodesk Map 3D 2007 with Service Pack 3 (acdbmgd.dll version
17.0.116.0)
- OSGeo.MySQL.3.1 FDO provider that got installed along Map's SP3
(providers.xml)
First of all, there's libmySQL.dll missing in Map's ..\FDO\bin folder. I
noticed (Autodesk NGs) that people are using MySQL ODBC driver instead,
which brings in too many drawbacks. Officially, Autodesk supports MySQL
5.0.22 so I had to grab missing library from the archive (
http://downloads.mysql.com/archives.php?p=mysql-5.0
http://downloads.mysql.com/archives.php?p=mysql-5.0 ). I just copied the
file libmySQL.dll from archive into Map's ..\FDO\bin folder and Map
finally
started noticing present MySQL Server instance :-) Good for now...
MySQL Server has a "root" account I had to use while establishing
connection
within Map. Service name is actually MySQL's host name (e.g. "server").
So I
went to the next step - creating named DataStore. After setting up
coordinate system parameters, along with it's extents (storage
resolution of
0.0001), I went further to see how Map creates a datastore... or
doesn't, in
my particular case :-)
Here's what happens - after the step where FDO schema and tables (f_*)
get
created, Map issues CreateSpatialContext which fails in a spectacular
way -
it actually kills MySQL Server instance/service!
Do you have any suggestions or workarounds to this?
With kindest regards,
Maksim Sestic
View this message in context:
http://www.nabble.com/FDO%2C-Map-2007-and-MySQL-Server-tf4533886s18162.h
tml#a12938770
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
