[fdo-users] Can you execute an FDO Spatial filter on x,y data
in oledb datasource?
Nick Adams
nick.adams at 1spatial.com
Tue Apr 29 04:33:10 EDT 2008
Gavin Cramer wrote:
> Hi, Nick. You should be able to do this now via the FDO ODBC Provider.
> It maps X and Y ordinate columns to a property named 'Geometry'. It
> natively does this for columns named 'X', 'Y', 'x' or 'y' (and optionally
> 'Z'/'z'). I believe that both Map3D and MapGuide also add their own logic
> to sense columns with names like 'LATITUDE' and 'LONGITUDE' as well as
> having schema menus where you can map any other numeric columns to be the
> ordinates.
> Does this help?
> Gavin
Thanks Gavin, it worked like a charm.
Nick
View this message in context: http://www.nabble.com/Can-you-execute-an-FDO-Spatial-filter-on-x%2Cy-data-in-oledb-datasource--tp16807717p16955726.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
