[fdo-users] Can you execute an FDO Spatial filter on x,
y datain oledb datasource?
Crispin Hoult
crispin.hoult at 1spatial.com
Tue Apr 29 04:37:04 EDT 2008
I saw this - did Ross or Alan forward to you a txt I send from Paris
with a similar solution, ie that you just put "Geometry" in as the
spatial filter column.
The 'correct' way to do this is to use the get capabilities of the
provider to query the geom columns.
So - are UC4 and UC5 done?
Crispin
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Nick Adams
Sent: 29 April 2008 09:33
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] Can you execute an FDO Spatial filter on x,y
Gavin Cramer wrote:
> Hi, Nick. You should be able to do this now via the FDO ODBC
Provider.
> It maps X and Y ordinate columns to a property named 'Geometry'. It
> natively does this for columns named 'X', 'Y', 'x' or 'y' (and
> optionally 'Z'/'z'). I believe that both Map3D and MapGuide also add
> their own logic to sense columns with names like 'LATITUDE' and
> 'LONGITUDE' as well as having schema menus where you can map any other
> numeric columns to be the ordinates.
> Does this help?
> Gavin
Thanks Gavin, it worked like a charm.
Nick
View this message in context:
http://www.nabble.com/Can-you-execute-an-FDO-Spatial-filter-on-x%2Cy-dat
a-in-oledb-datasource--tp16807717p16955726.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
