[fdo-users] OGR 3.3 Provider runtime error [SOLVED]
Traian Stanev
traian.stanev at autodesk.com
Tue Feb 5 15:37:44 EST 2008
That is just bizarre. Shows you how much I understand that manifest thing though. Yes, that's probably the right fix.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, February 05, 2008 2:00 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error [SOLVED]
> I solved the problem, but it was the other way round.
> The release configuration for the OGRProvider vcproj *did not* have
> manifest
> generation and embedding enabled. I turned these options on, rebuilt
> the
> project and now I no longer get the runtime errors.
> I don't work with VC++ that much, so I dunno if this qualifies as an
> actual
> "fix", but there you have it.
> - Jackie
> Traian Stanev wrote:
> > The depends dump looks good, however I just thought of what may be
> causing
> > this. Some time ago Kenneth posted about a similar problem. I
> remember him
> > mentioning that it was due to a manifest being embedded in the
> OGRProvider
> > dll at build time. Removing the embedded manifest fixed the problem
> for
> > him. We need to check the OGRProvider vcproj file for that problem
> and fix
> > it if the manifest is turned on.
> > Traian
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> > Sent: Thursday, January 24, 2008 11:07 PM
> > Depends can export the dependency graph to a file. If you could
> export
> > yours and send it over I can take a quick look. Since the file can be
> > large, email it to me only.
> > Traian
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> > Sent: Thursday, January 24, 2008 11:04 PM
> > That is correct, there are no red C++ functions listed.
> > - Jackie
> >> So, you open depends for OGRProvider.dll, pick FDO.dll from the
> tree-view
> >> on the top left, and then look on the right side. It will show
> functions
> >> from FDO.dll that the OGRProvider calls. Most of them will have a
> green
> >> "C++" next to them. Are you saying none of them have a red C++ if
> you do
> >> this?
> >> Traian
> >>> Sent: Tuesday, January 22, 2008 3:03 AM
> >>> I've combed through the list of functions (OGRProvider.dll and
> directly
> >>> related dlls) and couldn't find any red ones. However the log
> window
> >>> did say
> >>> there was at least one unresolved export function in one of the
> delay-
> >>> load
> >>> dependent modules, but it doesn't say which one??
> >>> - Jackie
> >>> > DWMAPI.dll is a common false positive that depends throws. That's
> not
> >>> your
> >>> > actual problem.
> >>> > In depends, look in one of the right panes (the one in the
> middle,
> >>> not the
> >>> > top right), where it lists all the dependent DLL functions that
> are
> >>> needed
> >>> > by the provider. See if any of them are listed in red.
> >>> > Traian
> >>> > ________________________________________
> >>> > [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> >>> > [jackie.ng at aecsystems.com.au]
> >>> > Sent: Monday, January 21, 2008 11:49 PM
> >>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
> >>> > Hi List,
> >>> > I have an application that interrogates a provider's connection
> >>> > properties,
> >>> > but when I want to get the connection properties of the OGR
> provider.
> >>> I
> >>> > get
> >>> > the following error:
> >>> > Microsoft Visual C++ Runtime Library
> >>> > Runtime Error!
> >>> > Program: [path to executable]
> >>> > R6034
> >>> > An Application has made an attempt to load the C runtime library
> >>> > incorrectly.
> >>> > Please contact the application's support team for more
> information.
> >>> > If I run this through the vs debugger, I get an unhandled
> >>> > OSGeo.FDO.Common.Exception with the following message.
> >>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
> >>> > initialization routine failed."
> >>> > Running OGRProvider.dll through depends.exe, I found that it was
> has
> >>> a
> >>> > missing dependency dwmapi.dll, which after some googling turns
> out to
> >>> be a
> >>> > Windows Vista dll (???). So I downloaded the file anyway, and put
> it
> >>> into
> >>> > the working directory, but I still get the same error messages.
> >>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on
> Windows
> >>> XP.
> >>> > I am using the managed dlls.
> >>> > Any ideas?
> >>> > - Jackie
> >>> > View this message in context:
> >>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
> >>> tp15012644s18162p15012644.html
> >>> > Sent from the fdo-users mailing list archive at Nabble.com.
> >>> > _______________________________________________
> >>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> >>> View this message in context: http://www.nabble.com/OGR-3.3-
> Provider-
> >>> runtime-error-tp15012644s18162p15014222.html
> tp15012644s18162p15080594.html
> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
> runtime-error-tp15012644s18162p15296982.html
More information about the fdo-users
