[fdo-users] OGR 3.3 Provider runtime error [SOLVED]
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Feb 5 13:59:58 EST 2008
I solved the problem, but it was the other way round.
The release configuration for the OGRProvider vcproj *did not* have manifest
generation and embedding enabled. I turned these options on, rebuilt the
project and now I no longer get the runtime errors.
I don't work with VC++ that much, so I dunno if this qualifies as an actual
"fix", but there you have it.
- Jackie
Traian Stanev wrote:
> The depends dump looks good, however I just thought of what may be causing
> this. Some time ago Kenneth posted about a similar problem. I remember him
> mentioning that it was due to a manifest being embedded in the OGRProvider
> dll at build time. Removing the embedded manifest fixed the problem for
> him. We need to check the OGRProvider vcproj file for that problem and fix
> it if the manifest is turned on.
> Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Thursday, January 24, 2008 11:07 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
> Depends can export the dependency graph to a file. If you could export
> yours and send it over I can take a quick look. Since the file can be
> large, email it to me only.
> Traian
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Thursday, January 24, 2008 11:04 PM
> That is correct, there are no red C++ functions listed.
> - Jackie
>> So, you open depends for OGRProvider.dll, pick FDO.dll from the tree-view
>> on the top left, and then look on the right side. It will show functions
>> from FDO.dll that the OGRProvider calls. Most of them will have a green
>> "C++" next to them. Are you saying none of them have a red C++ if you do
>> this?
>> Traian
>>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>>> Sent: Tuesday, January 22, 2008 3:03 AM
>>> I've combed through the list of functions (OGRProvider.dll and directly
>>> related dlls) and couldn't find any red ones. However the log window
>>> did say
>>> there was at least one unresolved export function in one of the delay-
>>> load
>>> dependent modules, but it doesn't say which one??
>>> - Jackie
>>> > DWMAPI.dll is a common false positive that depends throws. That's not
>>> your
>>> > actual problem.
>>> > In depends, look in one of the right panes (the one in the middle,
>>> not the
>>> > top right), where it lists all the dependent DLL functions that are
>>> needed
>>> > by the provider. See if any of them are listed in red.
>>> > Traian
>>> > ________________________________________
>>> > [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>>> > [jackie.ng at aecsystems.com.au]
>>> > Sent: Monday, January 21, 2008 11:49 PM
>>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
>>> > Hi List,
>>> > I have an application that interrogates a provider's connection
>>> > properties,
>>> > but when I want to get the connection properties of the OGR provider.
>>> I
>>> > get
>>> > the following error:
>>> > Microsoft Visual C++ Runtime Library
>>> > Runtime Error!
>>> > Program: [path to executable]
>>> > R6034
>>> > An Application has made an attempt to load the C runtime library
>>> > incorrectly.
>>> > Please contact the application's support team for more information.
>>> > If I run this through the vs debugger, I get an unhandled
>>> > OSGeo.FDO.Common.Exception with the following message.
>>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
>>> > initialization routine failed."
>>> > Running OGRProvider.dll through depends.exe, I found that it was has
>>> a
>>> > missing dependency dwmapi.dll, which after some googling turns out to
>>> be a
>>> > Windows Vista dll (???). So I downloaded the file anyway, and put it
>>> into
>>> > the working directory, but I still get the same error messages.
>>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows
>>> XP.
>>> > I am using the managed dlls.
>>> > Any ideas?
>>> > - Jackie
>>> > View this message in context:
>>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
>>> tp15012644s18162p15012644.html
>>> > Sent from the fdo-users mailing list archive at Nabble.com.
>>> > _______________________________________________
>>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>>> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
>>> runtime-error-tp15012644s18162p15014222.html
> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15080594.html
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15296982.html
More information about the fdo-users
