[fdo-users] OGR 3.3 Provider runtime error
Jackie Ng jackie.ng at aecsystems.com.au
Mon Feb 4 22:54:51 EST 2008
I ran this code on a fresh windows xp virtual machine (installed the SP1
runtime beforehand) and it complains about not being able to find
msvcp80.dll (!?)
So next thing I did was copy the runtime dlls directly into the executable
directory. Now I get the same R6034 error.
Ok, I've aggressively pursued all lines of inquiry regarding the R6034
error, and as a result, I've tried building the OGR provider from source
with a statically linked runtime library (/MT), and now I can get the
connection properties of the provider, but now I get a different error
(R6025 - pure virtual function call)
Nevertheless, I now inclined to believe that it is nothing to do with FDO
but rather to do with the VC++ 2005 runtime library.
Why could it not detect the runtime dlls?
- Jackie
Jackie Ng wrote:
> It was a release build.
> - Jackie
> Traian Stanev wrote:
>> Were you doing a Debug or Release build?
>> ________________________________________
>> From: fdo-users-bounces at lists.osgeo.org
>> [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> [jackie.ng at aecsystems.com.au]
>> Sent: Wednesday, January 30, 2008 7:20 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
>> I've built FDO and providers from source, and still get the error.
>> I've set manifest to off in the OGRProvider vcproj file, rebuilt
>> everything
>> from source, still no good.
>> I rewrote the C# test code in native C++, still the same error.
>> I'm out of ideas :(
>> - Jackie
>>> The depends dump looks good, however I just thought of what may be
>>> causing
>>> this. Some time ago Kenneth posted about a similar problem. I remember
>>> him
>>> mentioning that it was due to a manifest being embedded in the
>>> OGRProvider
>>> dll at build time. Removing the embedded manifest fixed the problem for
>>> him. We need to check the OGRProvider vcproj file for that problem and
>>> fix
>>> it if the manifest is turned on.
>>> Traian
>>> -----Original Message-----
>>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
>>> Sent: Thursday, January 24, 2008 11:07 PM
>>> Depends can export the dependency graph to a file. If you could export
>>> yours and send it over I can take a quick look. Since the file can be
>>> large, email it to me only.
>>> Traian
>>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>>> Sent: Thursday, January 24, 2008 11:04 PM
>>> That is correct, there are no red C++ functions listed.
>>> - Jackie
>>>> So, you open depends for OGRProvider.dll, pick FDO.dll from the
>>>> tree-view
>>>> on the top left, and then look on the right side. It will show
>>>> functions
>>>> from FDO.dll that the OGRProvider calls. Most of them will have a green
>>>> "C++" next to them. Are you saying none of them have a red C++ if you
>>>> do
>>>> this?
>>>> Traian
>>>>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>>>>> Sent: Tuesday, January 22, 2008 3:03 AM
>>>>> I've combed through the list of functions (OGRProvider.dll and
>>>>> directly
>>>>> related dlls) and couldn't find any red ones. However the log window
>>>>> did say
>>>>> there was at least one unresolved export function in one of the delay-
>>>>> load
>>>>> dependent modules, but it doesn't say which one??
>>>>> - Jackie
>>>>> > DWMAPI.dll is a common false positive that depends throws. That's
>>>>> not
>>>>> your
>>>>> > actual problem.
>>>>> > In depends, look in one of the right panes (the one in the middle,
>>>>> not the
>>>>> > top right), where it lists all the dependent DLL functions that are
>>>>> needed
>>>>> > by the provider. See if any of them are listed in red.
>>>>> > Traian
>>>>> > Sent: Monday, January 21, 2008 11:49 PM
>>>>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
>>>>> > Hi List,
>>>>> > I have an application that interrogates a provider's connection
>>>>> > properties,
>>>>> > but when I want to get the connection properties of the OGR
>>>>> provider.
>>>>> I
>>>>> > get
>>>>> > the following error:
>>>>> > Microsoft Visual C++ Runtime Library
>>>>> > Runtime Error!
>>>>> > Program: [path to executable]
>>>>> > R6034
>>>>> > An Application has made an attempt to load the C runtime library
>>>>> > incorrectly.
>>>>> > Please contact the application's support team for more information.
>>>>> > If I run this through the vs debugger, I get an unhandled
>>>>> > OSGeo.FDO.Common.Exception with the following message.
>>>>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
>>>>> > initialization routine failed."
>>>>> > Running OGRProvider.dll through depends.exe, I found that it was has
>>>>> a
>>>>> > missing dependency dwmapi.dll, which after some googling turns out
>>>>> to
>>>>> be a
>>>>> > Windows Vista dll (???). So I downloaded the file anyway, and put it
>>>>> into
>>>>> > the working directory, but I still get the same error messages.
>>>>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on
>>>>> Windows
>>>>> XP.
>>>>> > I am using the managed dlls.
>>>>> > Any ideas?
>>>>> > - Jackie
>>>>> > View this message in context:
>>>>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
>>>>> tp15012644s18162p15012644.html
>>>>> > Sent from the fdo-users mailing list archive at Nabble.com.
>>>>> > _______________________________________________
>>>>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>>>>> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
>>>>> runtime-error-tp15012644s18162p15014222.html
>>> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15080594.html
>> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15195091.html
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15283068.html
More information about the fdo-users mailing list
