[fdo-users] FDO MySQL Defect : wrong column type in SQLCommand
Orest Halustchak
orest.halustchak at autodesk.com
Wed Jan 2 08:42:43 EST 2008
Hi Bruno,
Do you know if an FDO Select command on the same table returns the correct data types and string lengths for these columns?
You should go ahead and create a ticket for these issues.
Thanks,
Orest.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Wednesday, January 02, 2008 3:58 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO MySQL Defect : wrong column type in SQLCommand
When i use a fdoMySql native query using FdoISQLCommand
i don't get back the right column type in the FdoISQLDataReader
All int32 column are returned as Double
All String column are returned with a length of 255 characters.
Bruno
View this message in context: http://www.nabble.com/FDO-MySQL-Defect-%3A-wrong-column-type-in-SQLCommand-tp14575229s18162p14575229.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
