[fdo-users] FDO MySQL Defect : wrong column type in SQLCommand
Bruno Scott
bscott at geomapgis.com
Wed Jan 2 09:05:26 EST 2008
Yes a FDO Select command return the correct data type
I will enter a ticket
Thanks Orest
Orest Halustchak wrote:
> Hi Bruno,
> Do you know if an FDO Select command on the same table returns the correct
> data types and string lengths for these columns?
> You should go ahead and create a ticket for these issues.
> Thanks,
> Orest.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Wednesday, January 02, 2008 3:58 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] FDO MySQL Defect : wrong column type in SQLCommand
> When i use a fdoMySql native query using FdoISQLCommand
> i don't get back the right column type in the FdoISQLDataReader
> All int32 column are returned as Double
> All String column are returned with a length of 255 characters.
> Bruno
> http://www.nabble.com/FDO-MySQL-Defect-%3A-wrong-column-type-in-SQLCommand-tp14575229s18162p14575229.html
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/FDO-MySQL-Defect-%3A-wrong-column-type-in-SQLCommand-tp14575229s18162p14578932.html
More information about the fdo-users
