[fdo-users] FDO SDF Defect : count is case sensitive
Badreddine Karoui
badreddine.karoui at autodesk.com
Wed Jan 2 09:09:52 EST 2008
This should work in the latest code stream. All function are case insensitive.
Badreddine
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Wednesday, January 02, 2008 9:03 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO SDF Defect : count is case sensitive
In SelectAggregates i use this type of query
Select count(1) from mytable
With SDF provider it throw an "unsupported function" exception
It works well with the MySQL provider
Didn't test any other provider yet.
This syntax works:
Select Count(1) from mytable
Bruno
View this message in context: http://www.nabble.com/FDO-SDF-Defect-%3A-count-is-case-sensitive-tp14578740s18162p14578740.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
