[fdo-users] FDO 3.1 vs 3.2
George McLean
gmclean at gorge.net
Wed Jan 2 14:17:58 EST 2008
I just thought I would follow up with a fix for the unsupported geometry
type error I was getting. This may already be well known but I thought
someone might benefit from my experience. From what I can tell osgeo.fdo
geometry types do not support Z or M in the definition of the geometry.
I changed the dimensionality in the call to gf.CreatePoint from 2 which
gave me XYZM to 0 which gave me XY. This also worked with the call to
CreateLineString.
George
George McLean wrote:
> Hello,
> I am finally getting around to updating a .NET application to run in
> Map 2008 so I am running into some issues using the FDO 3.2 libraries.
> In the code below I am using the MySQL provider to insert point
> objects into a MySQL database. I get an error "Unsupported Geometry
> Type" for all my points using the following code.
> ' Load the geometry object
> Dim d(3) As Double
> d(0) = BlRef.Position.X
> d(1) = BlRef.Position.Y
> d(2) = BlRef.Position.Z
> Dim geoPoint As OSGeo.FDO.Geometry.IPoint
> geoPoint = gf.CreatePoint(3, d)
> Dim byteArray() As Byte
> byteArray = gf.GetFgf(geoPoint) ' gf.GetAgf(geoPoint)
> fdoGeoData = New OSGeo.FDO.Expression.GeometryValue(byteArray)
> fdoPropertyValue = New
> OSGeo.FDO.Commands.PropertyValue("geometry", fdoGeoData)
> fdoValueCollectionIndex = fdoPropertyValues.Add(fdoPropertyValue)
> ' Insert into FDO
> Dim fdoFeatureReader As osgeo.Fdo.Commands.Feature.IFeatureReader
> Try
> fdoFeatureReader = fdoInsertObject.Execute()
> fdoTrans.Commit()
> fdoFeatureReader.Dispose()
> This code was working fine using the appropriate FDO 3.1 libraries. I
> have similar code for loading LineString features that also fails in
> 3.2. Any suggestions on how to debug this?
> Thanks
> George McLean
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
