[fdo-users] ISelect and ISQLCommand Usage
Crispin at 1Spatial
Crispin.Hoult at 1Spatial.com
Mon Jan 7 08:57:36 EST 2008
Thanks - a partial success and perhaps something for the bug list...
Using the SHP provider I could use GetPropertyNames and add to the column
list all OK.
But with the King.Oracle.0.1.1 on FDO 3.2.3 (3.2.2.66) I get an Oracle
error.
Exception:
OSGeo.FDO.Common.Exception was unhandled
Message="ORA-29902: error in executing ODCIIndexStart()
routine\nORA-13208: internal error while evaluating [window SRID does not
match layer SRID] operator\nORA-06512: at \"MDSYS.SDO_INDEX_METHOD_10I\",
line 474\nORA-06512: at line 1\n"
Source="OSGeo.FDO"
StackTrace:
at OSGeo.FDO.Commands.Feature.ISelectImp.Execute()
Code sample:
if ("King.Oracle.0.1.1" != sourceConnection.ConnectionInfo.ProviderName)
OSGeo.FDO.Commands.IdentifierCollection colFields;
colFields = selectCommand.PropertyNames;
OSGeo.FDO.Expression.Identifier idField2 = new
OSGeo.FDO.Expression.Identifier(szGeometry);
colFields.Add(idField2);
OSGeo.FDO.Expression.Identifier idField1 = new
OSGeo.FDO.Expression.Identifier(szLayerField);
colFields.Add(idField1);
In theory, you should be able to query only certain columns using an
FdoISelect. There is a GetPropertyNames() call on the FdoISelect object. It
returns a collection of property names that you can add to. If the
collection is empty, all columns are returned, otherwise, the specified
columns are returned.
However, I bet the implementation of this varies across providers.
Traian
View this message in context: http://www.nabble.com/ISelect-and-ISQLCommand-Usage-tp14618931s18162p14666502.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
