Re[fdo-users] distributing FDO - "The specified module could
not be found"?
Greg Boone
greg.boone at autodesk.com
Mon Jan 14 17:48:41 EST 2008
It looks as if a DLL is missing from the path. Do you have all the FDO binaries in the path, managed and unmanaged? Also, try and run the depends.exe application to see if it can tell you what binary is missing. Thirdly, check the content of providers.xml to ensure that the provider path locations are correct.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Crispin @ 1Spatial
Sent: Monday, January 14, 2008 12:28 PM
To: fdo-users at lists.osgeo.org
Subject: Re[fdo-users] distributing FDO - "The specified module could not be found"?
Hi Folks,
I appreciate that the .net assemblies for FDO are some kind of interoperable
wrappers to compiled DLLs below and not 100% managed code (if I have all my
terminology right). So when I just do a simple file-copy and call the first
function in the application I get the exception below. As none of the DLL's
register I must be missing something obvious?
Many thanks in advance,
Crispin
OSGeo.FDO.Common.Exception: Unable to load the FDO Provider: The specified
module could not be found.
at OSGeo.FDO.IConnectionManagerImp.CreateConnection(String providerName)
View this message in context: http://www.nabble.com/Redistributing-FDO---%22The-specified-module-could-not-be-found%22--tp14806626s18162p14806626.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
