[fdo-users] OGR 3.3 Provider runtime error
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Jan 21 23:49:17 EST 2008
Hi List,
I have an application that interrogates a provider's connection properties,
but when I want to get the connection properties of the OGR provider. I get
the following error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: [path to executable]
R6034
An Application has made an attempt to load the C runtime library
incorrectly.
Please contact the application's support team for more information.
If I run this through the vs debugger, I get an unhandled
OSGeo.FDO.Common.Exception with the following message.
"Unable to load the FDO Provider: A dynamic link library (DLL)
initialization routine failed."
Running OGRProvider.dll through depends.exe, I found that it was has a
missing dependency dwmapi.dll, which after some googling turns out to be a
Windows Vista dll (???). So I downloaded the file anyway, and put it into
the working directory, but I still get the same error messages.
I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows XP.
I am using the managed dlls.
Any ideas?
- Jackie
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15012644.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
