[fdo-users] OGR 3.3 Provider runtime error
Traian Stanev
traian.stanev at autodesk.com
Tue Jan 22 00:48:27 EST 2008
DWMAPI.dll is a common false positive that depends throws. That's not your actual problem.
In depends, look in one of the right panes (the one in the middle, not the top right), where it lists all the dependent DLL functions that are needed by the provider. See if any of them are listed in red.
Traian
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng [jackie.ng at aecsystems.com.au]
Sent: Monday, January 21, 2008 11:49 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] OGR 3.3 Provider runtime error
Hi List,
I have an application that interrogates a provider's connection properties,
but when I want to get the connection properties of the OGR provider. I get
the following error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: [path to executable]
R6034
An Application has made an attempt to load the C runtime library
incorrectly.
Please contact the application's support team for more information.
If I run this through the vs debugger, I get an unhandled
OSGeo.FDO.Common.Exception with the following message.
"Unable to load the FDO Provider: A dynamic link library (DLL)
initialization routine failed."
Running OGRProvider.dll through depends.exe, I found that it was has a
missing dependency dwmapi.dll, which after some googling turns out to be a
Windows Vista dll (???). So I downloaded the file anyway, and put it into
the working directory, but I still get the same error messages.
I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows XP.
I am using the managed dlls.
Any ideas?
- Jackie
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15012644.html
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
