[fdo-users] OGR 3.3 Provider runtime error
Jack Lee
jack.lee at autodesk.com
Tue Jan 22 09:12:03 EST 2008
FDO 3.3.0 RC1 was built with Visual Studio 2005 SP1.
Do you have Visual Studio 2005 SP1 or Visual Studio 2005 SP1 runtime installed?
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, January 22, 2008 3:03 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
I've combed through the list of functions (OGRProvider.dll and directly
related dlls) and couldn't find any red ones. However the log window did say
there was at least one unresolved export function in one of the delay-load
dependent modules, but it doesn't say which one??
- Jackie
Traian Stanev wrote:
> DWMAPI.dll is a common false positive that depends throws. That's not your
> actual problem.
> In depends, look in one of the right panes (the one in the middle, not the
> top right), where it lists all the dependent DLL functions that are needed
> by the provider. See if any of them are listed in red.
> Traian
> ________________________________________
> [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> [jackie.ng at aecsystems.com.au]
> Sent: Monday, January 21, 2008 11:49 PM
> Subject: [fdo-users] OGR 3.3 Provider runtime error
> Hi List,
> I have an application that interrogates a provider's connection
> properties,
> but when I want to get the connection properties of the OGR provider. I
> get
> the following error:
> Microsoft Visual C++ Runtime Library
> Runtime Error!
> Program: [path to executable]
> R6034
> An Application has made an attempt to load the C runtime library
> incorrectly.
> Please contact the application's support team for more information.
> If I run this through the vs debugger, I get an unhandled
> OSGeo.FDO.Common.Exception with the following message.
> "Unable to load the FDO Provider: A dynamic link library (DLL)
> initialization routine failed."
> Running OGRProvider.dll through depends.exe, I found that it was has a
> missing dependency dwmapi.dll, which after some googling turns out to be a
> Windows Vista dll (???). So I downloaded the file anyway, and put it into
> the working directory, but I still get the same error messages.
> I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows XP.
> I am using the managed dlls.
> Any ideas?
> - Jackie
> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15012644.html
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15014222.html
More information about the fdo-users
