[fdo-users] OGR 3.3 Provider runtime error
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Jan 22 10:09:08 EST 2008
Yes, I have both VS2005 SP1 and runtime installed.
- Jackie
Jack Lee-3 wrote:
> Hi,
> FDO 3.3.0 RC1 was built with Visual Studio 2005 SP1.
> Do you have Visual Studio 2005 SP1 or Visual Studio 2005 SP1 runtime
> installed?
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, January 22, 2008 3:03 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
> I've combed through the list of functions (OGRProvider.dll and directly
> related dlls) and couldn't find any red ones. However the log window did
> say
> there was at least one unresolved export function in one of the delay-load
> dependent modules, but it doesn't say which one??
> - Jackie
> Traian Stanev wrote:
>> DWMAPI.dll is a common false positive that depends throws. That's not
>> your
>> actual problem.
>> In depends, look in one of the right panes (the one in the middle, not
>> the
>> top right), where it lists all the dependent DLL functions that are
>> needed
>> by the provider. See if any of them are listed in red.
>> Traian
>> ________________________________________
>> [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> [jackie.ng at aecsystems.com.au]
>> Sent: Monday, January 21, 2008 11:49 PM
>> Subject: [fdo-users] OGR 3.3 Provider runtime error
>> Hi List,
>> I have an application that interrogates a provider's connection
>> properties,
>> but when I want to get the connection properties of the OGR provider. I
>> get
>> the following error:
>> Microsoft Visual C++ Runtime Library
>> Runtime Error!
>> Program: [path to executable]
>> R6034
>> An Application has made an attempt to load the C runtime library
>> incorrectly.
>> Please contact the application's support team for more information.
>> If I run this through the vs debugger, I get an unhandled
>> OSGeo.FDO.Common.Exception with the following message.
>> "Unable to load the FDO Provider: A dynamic link library (DLL)
>> initialization routine failed."
>> Running OGRProvider.dll through depends.exe, I found that it was has a
>> missing dependency dwmapi.dll, which after some googling turns out to be
>> a
>> Windows Vista dll (???). So I downloaded the file anyway, and put it into
>> the working directory, but I still get the same error messages.
>> I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows XP.
>> I am using the managed dlls.
>> Any ideas?
>> - Jackie
>> View this message in context:
>> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15012644.html
>> Sent from the fdo-users mailing list archive at Nabble.com.
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15014222.html
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15020398.html
More information about the fdo-users
