[fdo-users] OGR 3.3 Provider runtime error
Traian Stanev
traian.stanev at autodesk.com
Tue Jan 22 10:07:01 EST 2008
So, you open depends for OGRProvider.dll, pick FDO.dll from the tree-view on the top left, and then look on the right side. It will show functions from FDO.dll that the OGRProvider calls. Most of them will have a green "C++" next to them. Are you saying none of them have a red C++ if you do this?
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, January 22, 2008 3:03 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
> I've combed through the list of functions (OGRProvider.dll and directly
> related dlls) and couldn't find any red ones. However the log window
> did say
> there was at least one unresolved export function in one of the delay-
> load
> dependent modules, but it doesn't say which one??
> - Jackie
> Traian Stanev wrote:
> > DWMAPI.dll is a common false positive that depends throws. That's not
> your
> > actual problem.
> > In depends, look in one of the right panes (the one in the middle,
> not the
> > top right), where it lists all the dependent DLL functions that are
> needed
> > by the provider. See if any of them are listed in red.
> > Traian
> > ________________________________________
> > [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> > [jackie.ng at aecsystems.com.au]
> > Sent: Monday, January 21, 2008 11:49 PM
> > Subject: [fdo-users] OGR 3.3 Provider runtime error
> > Hi List,
> > I have an application that interrogates a provider's connection
> > properties,
> > but when I want to get the connection properties of the OGR provider.
> I
> > get
> > the following error:
> > Microsoft Visual C++ Runtime Library
> > Runtime Error!
> > Program: [path to executable]
> > R6034
> > An Application has made an attempt to load the C runtime library
> > incorrectly.
> > Please contact the application's support team for more information.
> > If I run this through the vs debugger, I get an unhandled
> > OSGeo.FDO.Common.Exception with the following message.
> > "Unable to load the FDO Provider: A dynamic link library (DLL)
> > initialization routine failed."
> > Running OGRProvider.dll through depends.exe, I found that it was has
> a
> > missing dependency dwmapi.dll, which after some googling turns out to
> be a
> > Windows Vista dll (???). So I downloaded the file anyway, and put it
> into
> > the working directory, but I still get the same error messages.
> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows
> XP.
> > I am using the managed dlls.
> > Any ideas?
> > - Jackie
> > View this message in context:
> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
> tp15012644s18162p15012644.html
> > Sent from the fdo-users mailing list archive at Nabble.com.
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
> runtime-error-tp15012644s18162p15014222.html
More information about the fdo-users
