[fdo-users] Is there a Feature class naming convention
Bruno Scott
bscott at geomapgis.com
Tue Jan 22 10:33:01 EST 2008
When we create a feature class, let say using the MySQL provider we give a
feature class name example: "MyFeatureClass"
and when we query it we use the same "MyFeatureClass"
This is fine...
With the PostGIS provider, we create the feature with a name like
"MyFeatureClass"
but we query with a different name example "MySchema.MyFeatureClass"
We have this same problem with the King.Oracle provider
When you have an application that uses any FDO RDBMS provider, it makes
things very difficult to handle.
We need to hardcode
"if provider == PostGis" then
"if provider == KingOracle then
And it is a bit against the FDO philosophy, a single language to address the
same way any spatial database,file
It there a reason for that different naming?
Bruno Scott
View this message in context: http://www.nabble.com/Is-there-a-Feature-class-naming-convention-tp15021175s18162p15021175.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
