[fdo-users] Is there a Feature class naming convention
Traian Stanev
traian.stanev at autodesk.com
Tue Jan 22 12:42:36 EST 2008
Yes, if the provider can create tables, this would be a problem to fix.
The OGR provider can't do that, but I think the Kind provider can, so it may need fixing.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
> Sent: Tuesday, January 22, 2008 12:35 PM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] Is there a Feature class naming convention
> There are two scenarios.
> If the provider is accessing an existing schema, e.g. not created by
> fdo, then the provider decides how to map the table / file to a class
> and schema. The main thing is that the mapping is unique and
> unambiguous as Traian said.
> The other scenario is if a new class is defined via fdo. In this case,
> the caller is specifying an explicit schema name and class name. A
> describe of that class then should come back with the same names as
> long as the input names were valid (FdoISchemaCapabilities has methods
> to get information about valid names such as name size limits and valid
> characters).
> Thanks,
> Orest.
> bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Tuesday, January 22, 2008 12:11 PM
> To: fdo-users at lists.osgeo.org
> >From what I vaguely remember (and I wrote that code in the OGR
> provider), some OGRLayers (which correspond to FDO feature classes in
> the OGR provider) came back with a . in the name. Basically the OGR
> Layer name was of the form "TABLE.CLASS" or something like that, and
> that whole string corresponds to one feature class. Since "." was not a
> valid character for FDO, I replaced it by ~ in such cases.
> Note that all of these feature classes are expressed as belonging to a
> single OGR connection schema called OGRSchema. So you can access the
> feature class "TABLE.LAYER" using:
> OGRSchema:TABLE~LAYER
> The OGR provider takes care of this transparently when going back to
> the database and will convert that back to TABLE.LAYER.
> As long as you are using the FDO API to do all this, it will work fine
> and complies with the FDO naming conventions. The class name is not
> ambiguous and the provider knows exactly what to do as long as you use
> that class name.
> What you are really questioning here is that the feature class name as
> reported by the FDO provider does not match the native table name in
> the database. Why is this a bug?
> Traian
> > bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> > Sent: Tuesday, January 22, 2008 11:55 AM
> > Subject: Re: [fdo-users] Is there a Feature class naming convention
> > When i query the className against the OGR PostGIS
> > it returns : MySchema~MyTable
> > When i query the className against the King.Oracle
> > it returns : MySchema~MyTable~myGeometryColumn
> > So if classname should be "MyTable" and fully qualified name
> > "MySchema:MyTable"
> > Can we consider this as a bug in these 2 providers?
> > Orest Halustchak wrote:
> > > I'm not sure why these providers would change the class names this
> > way.
> > > From FDO you can ask for class name and fully qualified class name
> > > separately so there should be no need to change the class name this
> > way.
> > > Class name should come back as "MyFeatureClass" and fully qualified
> > class
> > > name should come back as "MySchema:MyFeatureClass".
> > > Thanks,
> > > Orest.
> > > ------Original Message------
> > > From: Bruno Scott
> > > ReplyTo: FDO Users Mail List
> > > Sent: Jan 22, 2008 10:33 AM
> > > Subject: [fdo-users] Is there a Feature class naming convention
> > > When we create a feature class, let say using the MySQL provider we
> > give a
> > > feature class name example: "MyFeatureClass"
> > > and when we query it we use the same "MyFeatureClass"
> > > This is fine...
> > > With the PostGIS provider, we create the feature with a name like
> > > "MyFeatureClass"
> > > but we query with a different name example
> "MySchema.MyFeatureClass"
> > > We have this same problem with the King.Oracle provider
> > > When you have an application that uses any FDO RDBMS provider, it
> > makes
> > > things very difficult to handle.
> > > We need to hardcode
> > > "if provider == PostGis" then
> > > "if provider == KingOracle then
> > > And it is a bit against the FDO philosophy, a single language to
> > address
> > > the
> > > same way any spatial database,file
> > > It there a reason for that different naming?
> > > Bruno Scott
> > > View this message in context:
> > > http://www.nabble.com/Is-there-a-Feature-class-naming-convention-
> > tp15021175s18162p15021175.html
> > > Sent from the fdo-users mailing list archive at Nabble.com.
> > > _______________________________________________
> > > http://lists.osgeo.org/mailman/listinfo/fdo-users
> > > Sent from my BlackBerry Wireless Handheld
> > View this message in context: http://www.nabble.com/Is-there-a-
> Feature-
> > class-naming-convention-tp15021175s18162p15023058.html
More information about the fdo-users
